I think my power steering pump is going out
I guess I would be more concerned about the needle bearings and ball bearings on the input shaft, operating under a greater load without lubrication. I'm in the habit of considering the u-joints due to lots of experience with steering shafts that are a lot less beefy(my Ramcharger for example) and fail in normal use, let alone operating with increased effort.
Now I feel like an idiot, posted before I looked under the hood and found the belt had come off, has a slit in it and all I need is a new belt. Dodged the bullet on a semi expensive repair.
Thanks for the help
Cliff 87 $4 Murf # 44
Thanks for the help
