Moaning Sound
#32
I found a dial caliper @ harbor freight for 17$ Now I'll be able to provide a precise measurement.
http://www.harborfreight.com/cpi/cta...temnumber=5658
#33
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
1 Post
Plug in the above referenced numbers in the Harbor Freight search....
While your frustration factor might differ - Given that the caliper must be placed in the same exact place, which I found to be a pain in the ****....
Setting the magnetic base and run out mic on - and zero it - no mistake about the measurement. For $2 more, I assure you, you will appreciate the difference...
Not to mention the same settup comes in handy for many things on the car.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#34
Firemed, THANKS. There's a Harbor Freight pretty close to me, so i'll check it out. Also, I went and mixed the drained oil and put some on black cardboard. I do see some sparsely arranged particles that are left behind.
#38
The power steering pump will groan and moan sometimes, too. What fixed mine was a new power steering reservoir. Apparently the built-in filter in the reservoir was starving the pump.
