Cycling Key Fixes Problem???
Does anyone know what type of problem I have?
Typically revs increase with application of the go pedal
Maybe you've got a sticky throttle plate, or linkage, or throttle cable, or a piece of carpet keeping the gas pedal from coming all the way back up? Blow some Kroil down the throttle cable that goes to the pedal, and some down the cable that goes to the throttle body.
Dennis
Dennis
I don't understand how a bad ignition switch could be causing the car not to start? It turns over fine, is this a common problem? The car has been running fine now, I'm getting over all this real quick...
Then we would not have to make you an ***
or guess what kind of 928 we are trying to diagnose long distance over the internetGreg Phillips
BTW, Dennis is pretty sharp when it comes to the older cars, he was working on the best guess scenario given the lack of information in the original post !
That point clarified , from the new information it sounds like a relay, try swapping the LH relay with the horn. Get a fuse relay chart here www.928gt.com find page 2 then click on tips/links and download your year chart, keep it in the car.
With this piece of info you should check the fuses for their correct amperage and that you do infact have the correct part numbered relay in the correct position. Any relay that you remove can be opend up and check the internal contacts for arcing/burned also check the pins see if any look like they have corrosion on them if so then the blower box may need to be resealed.
Also smell the relays you remove, if they smell burned then they may be on their last legs
I'll add my scenario, 'cause this same problem on Rosy, isn't any of the points prior listed here.
Rosy is an '87 S4. Back in '01, or '02, I did have the relay failure situation.
A couple years ago, I had the same thing happen to me; no start, call the flat bed.
The tow vehicle gets there, go get something out of the passenger side, [ hear the electric locks cycle ] and just before the driver hooks Rosy up to pull up onto the flatbed, on a whim, I ask him to let me try to start Rosy again?
And Rosy fires right up.
What I have found, is that the driver's side door plunger, has stopped working. So, every once in awhile, the computer "senses" the lock system was engaged, and inhibits Rosy's starting system. Turns over, but no fire.
As it looks like replacing the plunger is difficult, I've learned that when Rosy won't fire off, get out, go 'round to the passenger side, open the door, actuate the door plunger [ and the locking system usually cycles, but not always ], even go so far as to operate the electric hatch opener, and Rosy fires right up.
Idiosyncratic, perhaps, but I'm not spending any cash....
BB79, go try operating the passenger and driver's door plungers, and see if'n the vehicle fires off?
