SharkTuner Mk 2
#437
Niklas suggests the following - "when you plug in a new device to the USB port, Windows usually displays that "Found new hardware, looking for drivers" pop up and it has a Cancel button. So you should just hit Cancel and so tell Windows not to try to install any drivers, then try to run the ST software".
#439
Does anyone runs the ST on Windows 10? I am not able to have a reliable connection (disconnect errors) between the ST and my laptop. I tried with different USB ports and different usb cables.
I am using my Mac Pro and BootCamp.
#440
Luc,
I've used ST2 with Win10 with no problems, but normally use my Win7 computer.
Does it start normally and load from PEMs OK? When does it disconnect? When the engine is running?
Have you tried a different computer, to rule out possible issues with BootCamp?
How is the computer powered? Try running it on battery, sometimes external computer power can create a ground loop (I never experienced problems with ST2, but with other external devices).
#442
Luc,
It think I found my issue - it looks like the usb connector on my Mac are not tight enought and permits the cable to move. I did a few runs last Monday and most of the disconnects happen after I hit a bump.
I will try another laptop.
Luc
#445
Just a thought since it is a chore with Windows, their versions and upgrades. Why don’t we have the application built on top of Linux micro kernel so it can be installed on any VM or bare metal and forget about the Windows OS?
#448
so...blowing the dust off some stuff here.
pulled out the sharktuner on the USB drive i had it on and plugged it into a MS surface pro...windows 10 pro...etc
cant get the program to load.
is the Sharktuner compatible with this "newer" surface pro or do i have to fish around on EBAY for an older "laptop"..
#449
Cheers, Jim
#450
George
90 S4 Grand Prix White (Murf #5 - 219.0 mph top speed)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
