Rod Bearing Replacement Question - Oil Pick Up Tube
I got out engine cross member and motor mounts last night. About to drop pan and begin rod bearings. Do I need to remove the oil pick up tube (suction tube) as I do not have the sealing ring, 928 107 136 04 that is shown where tube goes into block.
Thanks all
Thanks all
I did not remove the oil pick up tube when I did the rod bearings. However since you now have access to the tube it would be a good idea to replace the seal. They have been a source of low/no oil pressure and at some point will need to be replaced.
Also I am sure you already know this but just incase. You need to use new rod nuts when you replace the bearings. They are a one time use.
Thanks for the responses, looks like a call to Dave or Mark to get the seal + oil filter. Already have new rod bolts (ribbed). Pan is off, no sludge, very clean, car has close to 170K hard miles. Front bolts are a complete PIA, perhaps order stud kit from 928 motor-sports
Another question, what size fastener to use on the 928 GTS baffle that I am going to install?
Hard to believe, but I am actually enjoying doing this. After rod bearings and mounts, next issue is fixing the AC + suspension freshening
Got it covered. Using ANchor purchased from 928 Motorsports. I'll post a photo of old vs new as the old were not completely collapsed. WIll be refreshing trasmission mounts as well.
Back to under the car
