Perfect Power SMT-6 or SMT-8
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
This weekend I was talking to my fiancee's Dad about EMS and he had mentioned something called the Perfect Power SMT-8. I pulled up the website and found out that this piggyback type system can pretty much be applied to anything as long as you wire it right. It may not do everything a standalone EMS does, but it allows you to keep your stock ECU (namely the LH in our cars) and lies to it in order to richen and lean AFRs based on your preference for the most efficient and optimized performance.
From using the search, I saw Louie Ott used to use the SMT6, which is now obsolete and replaced by the SMT8 and it's predecessor the SMT7. Even though a piggyback does not have the flexibility of something like Electromotive, it does give you the ability to use and load various fuel maps and ignition maps as well.
Does anyone else have any experience and successes with a piggyback like Perfect Power's SMT-6, SMT-7, or SMT-8?
Man of many SIGs
I don't have personal experience but the people who I know that have used it all say it is a major PITA to use.
You keep asking about aftermarket engine management. What are you planning on modding w/ your car? Why not Shartktune?
Fuse 24 Assassin
Fuse 24 Assassin
I'm looking for a more efficient engine management system. The LH is efficient, don't get me wrong, but things are getting old on this system. I've been obsessing over TecGT for my S4, but I don't intend on doing any other serious modifications with the exception of a total EFI overhaul/conversion. I was looking for somethng that manages better AFRs in open loop mode at higher RPMs.
Since you had mentioned that PP is a PITA, I would rather stick with the original plan of going with Electromotive. But, what problems did you hear about and experiences with their setups?
Man of many SIGs
I just heard that it was very difficult to get working properly. Don't take my 2nd hand account to heart without first speaking with someone who has first hand knowledge.
Fuse 24 Assassin
Fuse 24 Assassin
I really like that fact that it's easier to swtich maps (i.e. for smog day). For the Sharktuner, I saw a thread a while back saying that another prom would have to be burned for a separate map.
Fleet of Foot
The PROM is extrordinarily easy to replace/swap. Buy a rebuilt LH for your Sharktuned PROM, you'll still come way out ahead $$ wise.
I've got the SMT 6 in my GT...easy to play with..and easy to bypass with the bypass plug.....Had Thurston wire it in...good enough for me just to modify the WOT map to get the A/F in line...
For the track car I went with a full megasquirt since I was faced with both a failed MAF and a bad LH brain....could have dropped $800 or so on replacements...and then continue to worry when it would fail again...or swap to megasquirt for about a grand (used system..Lizard)....and then tune to my liking...no distributors..and base map was provided (check for the thread on the install..its out there in renny land)..gained about 30 hp from this swap alone...
Plans for the GT are probably to go with a sharktuner (the rear turbo guy JT owes me a session
)..and I'll probably put in the flashable proms so I can just hook up a sharktuner to remap should I change anything on it..
Andy:
If all you are looking for is a way to switch maps, The LH / EZK setup can accomidate you. Take a look at the wiring diagrams for management coding plug. You can rig a multi pole switch and accomidate up multi map goal, all built into our LH / EZK system. Of course you'l need a Sharktuner, best with PEMs, to gain access.
Considering that you reside within the "Peeps Republik of CA", I'd sure look at all the issues of fitting an aftermarket system so that you can still pass a visual / functional inspection... that is, if you want to keep your car registered.
$0.02
$0.02
Fuse 24 Assassin
Fuse 24 Assassin
That's definitely something I'm considering. With a piggyback I can hide wiring. Sharktuner... no need to! Huge advantage there. If I do go the sharktuner route, I would prefer the PEM addon. I've heard bad thigns about using the Innovative Motorsports LM-1/LC-1 wideband O2 setup and opted for the AEM UEGO setup which does the same thing the LC-1 does as far as emulating signals. Dunno if it will work with John's Sharktuner though...
John Speake has programmable memory modules that replace the EEPROM chips. Put them in once and you don't need access to the LH & EZ-K again. The only connection you make to the LH and EZ-K is through your diagnostic plug. Connect a WB sensor to the Sharktuner and you are set up. Many people use the Innovate WB units. I like the TechEdge products (http://wbo2.com/home/products.htm), but others works too. The Sharktuner allows you to configure its WB input to correspond with your WB output whichever one you want to use. You can swap LH/EZ-K maps by downloading a different map from your laptop. Also, the LH & EZ-K always contain two maps each and you can switch between them using a switch on the configuration plug. One map for closed loop normal running and another map for open loop track setup, or for different fuel grades. They can be switched on the fly while driving if you want.
I have had an SMT-6 for years. It has not been difficult to use. Listen to Louie and Shark Tune. It is still on my list of things to do, if I didn't have the SMT-6 it would have been done already.
Rennlist Sponsor
Now, with the Sharktuner available there is no point in spending your time or money with it. I'm not sure why you seem so bent on switching from the LH/EZ-K to something else. They do a great job and you could buy your own Sharktuner for less than you'll spend on most stand alone systems. There is certainly no comparison when factoring in your time. The LH, as improved by John Speake, is as reliable as anything else you'll find.
Andy,
John Speake has programmable memory modules that replace the EEPROM chips. Put them in once and you don't need access to the LH & EZ-K again. The only connection you make to the LH and EZ-K is through your diagnostic plug. Connect a WB sensor to the Sharktuner and you are set up. Also, the LH & EZ-K always contain two maps each and you can switch between them using a switch on the configuration plug. One map for closed loop normal running and another map for open loop track setup, or for different fuel grades. They can be switched on the fly while driving if you want.
The SharkTuner is a no brainer, especially for an 87-95. Simple, effective, easy to install (and PEMs are the ONLY way to go) and VERY soon, VERY inexpensive.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
It takes about a minute to hook up a SharkTuner to a PEM equipped car to make a map change...a minute to load it and a minute to disconnect it...
I'm betting it doesn't get any easier than that!
