Timing belt 7.5 teeth off 86.5
#32
Yes.
Now that harmonic balancer is usless, just use the screwdriver to find TDC, see the mark on the harmonic balancer and move the cams 6 teeth and then lock flywheel and pull everything apart.
assemble in the same way and then, fine tune.worst case you will be a tooth off or so, but you can change that when you have it all together and are beginning to tighten things up.
mk
mk
Quote:
remember its 6 teeth advance at 45 degreee crank advanced. at that point you can lock the flywheel and start pulling things apart and move the cams
Should I count 6 teeth from the measured Tdc on piston # 1 to establish the 45 Degrees BTDC to make sure the cams don't crash if they rotate.
