Picked up an Escort Passport 8500 X50 yesterday Now for the hardwire
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I found this hardwire kit on ebay for the passport 8500 X50. It is not fused, but uses a fuse tap. Would this be adequate and safe to tap into the cigarette lighter fuse?
http://cgi.ebay.com/ESCORT-RADAR-DET...A1%7C294%3A200
Fuse 24 Assassin
Fuse 24 Assassin
Just bought it. Still looking for recommendations how to wire:
1) use fuse tap
2) buy LittleFuse Add-A-Circuit and combine.
1) use fuse tap
928 Collector
That kit looks crappy ..... but the Escort is a great detector!! You will love its exclusion circuitry. I've used only Escort in my cars for over 10 years and I am ticket-free.
You don't have to remove the CE panel completely; first identify an unused fuse socket that is powered on with the ignition, then just disconnect the battery, remove the hot wires from the studs at the top of the panel, then remove the two bolts at the top of the panel and rock it back.
Fleet of Foot
+1 with Dave. Those spade kits do nothing but stretch/distort the fuse terminal and render it almost useless if you ever take the terminal adapter out. Do it right.
Electron Wrangler
A combination approach:
do not use the fuse taps they supplied - they will wreck your fuseholders and the are crappy electrically & physically - whoever invented them should be taken out & beaten, boiled in oil & then shot repeatedly (they are that bad..).
Use an ATC add a circuit and connect to an ignition switched fuse. For orientation the wire must come out the bottom of the add a circuit when plugged in... use an ignition or accessory switched fuse that is in the 7.5-15A range - doesn't matter which one...
Alan
Alan
What I was suggesting is to use one of your empty fuse holders. Below is an example of how this was done on my early panel. Your later panel looks different but the same basic idea applies.
![](http://members.rennlist.com/sharkskin/Pages_SA_R04-FusePanelBack.jpg)
If you go with the add-a-circus idea cut off the crappy butt connector and break out the solder & heat-shrink. Crimp-style butt connectors, IMHO should ba(as Alan put it) "taken out & beaten, boiled in oil & then shot repeatedly" along with the shadetree taps. they can (and do) come loose and short to other stuff. They also can(and do) result in a poor connection that will leave you scratching your head somewhere down the road.
BTW, the butt connector and yellow terminal shown on the pic above are long gone, the connections have been re-done properly. Despite having done some stupid things, the PO (or some tech) made a decent effort to make a clean hookup for the extra circuit.
