If you have a 5-speed 928 and don't have a short throw shifter; GET ONE!
#61
Another great mod to go with the short shifter is Carl's **** adaptor for $8. It allows you to use any standard aftermarket ****. Switching to a more ergonomic **** makes the shifter feel more responsive and comfortable.
I would never go back to the Botton top **** after going with a grant evolution. Plus leather and burlwood just looks better IMO. Pic is first try. I have since cut the short shifter down another half inch. Carl's adaptor doesn't need the cut out so you can shorten any shifter hand with out having to make the cut out notches.
#64
#65
I am very glad you like the Short Shifter you got from us so much!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
#68
No, this is done internally inside the tranny. The springs on the original shift lever were mainly to keep it tighter feeling on the shift rod pins since they aren't as machined to a tight of a tolerance as the Short Shifters. Basically the originals were "sloppier on the rods" and the Short Shifters are a perfect fit.
The Short Shifters actually have a "snappier" spring back since they are a tighter fit to the shift rod pins and not as sloppy as the originals.
#70
This really sums it up. More precise, less slop!
#71
Just installed mine in the GTS the other day, took the car for a ride today and what a tremendous difference! THIS is how the car should have come from the factory. Very cheap and easy modification with fantastic results. Took me (yes, mechanically challenged me!) less than an hour start to finish including the test drive....
So your telling us your GTS is no longer 100% stock.
Actually I agree 100% The 928 GTS is a car that needs little improvement from the factory. The short shift and RMB are the 2 best improvements you can make although I am unhappy that my SS RMB is rusting at the flanges.
You might consider the 928 Specialist sway bars too. makes for much less body roll.
#73
I do plan to do some suspension work as you suggest. My GTS did not come with the optional sport suspension so it floats pretty bad so besides the sway bars I'll probably do new coilovers too and set the ride height down a bit. Additionally, I plan on doing more exhaust work besides the RMB, tint the windows, new wheels and perhaps some interior leather.
[edit] oh yeah, red calipers and drilled rotors bought from DR about 8 years ago..... being painted now!
#74
....and I've put more miles on it in two months then the guy I sold it to did in 15 months
#75
Many people would be happy with just a shorter shifter (lower ****) and stock throws, for a more ergonomic shifter and little increased shifting effort. A short shifter with stock and reduced arc rod locations might be a good product, then you could try both. Or you could take the grinder to your stock one and then go aftermarket if you decide you need more.
-Joel.
-Joel.
