928 Forum 1978-1995
Sponsored by: 928 Specialists
If you have a 5-speed 928 and don't have a short throw shifter; GET ONE!
Old 05-14-2009, 04:52 PM
Chuck Z
Chuck Z's Avatar
Default If you have a 5-speed 928 and don't have a short throw shifter; GET ONE!
Just installed mine in the GTS the other day, took the car for a ride today and what a tremendous difference! THIS is how the car should have come from the factory. Very cheap and easy modification with fantastic results. Took me (yes, mechanically challenged me!) less than an hour start to finish including the test drive....
Old 05-14-2009, 04:54 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
We happen to have 2 used short shifters in stock and they are $42. 85-95 only at this time.
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,555 Likes on 1,235 Posts
The PO installed one in the GTS that is considerably shorter than my stock '90 GT 'short' shifter- took me about 3 miles to get used to the difference but I really like it too. Snick, snick, snick....
Old 05-14-2009, 05:17 PM
Giovanni
Giovanni's Avatar
Mark, now you only have one left.
Old 05-14-2009, 05:27 PM
devilinblack
devilinblack's Avatar
Damn. Never any goodies for the 78's!
Old 05-14-2009, 05:29 PM
Rob Roy
On the Bandwagon
Rob Roy's Avatar
Just got one this week to install in my auto to manual conversion!
Old 05-14-2009, 05:41 PM
linderpat
linderpat's Avatar
Received 2,249 Likes on 1,253 Posts
What's the general procedure to swap out?
Old 05-14-2009, 05:51 PM
Chuck Z
Chuck Z's Avatar
1. remove the bottom of the boot from the console (without breaking it if possible - I didn't break mine)
2. pull the **** off the shift lever - takes a little effort and be careful not to use the console as a brace....
3. remove the rubber cover over the shifter well.
4. remove the two clips that hold the shifter lever to the rods.
5. remove the old shift lever, springs and plastic spacer (you will not reuse the springs or the white plastic spacer)
6. install the short shifter (not a bad idea to replace the 4 plastic bushings at the same time? there ~$2 each)
7. reinstall the washers and clips to hold everything in place.
8. reinstall the rubber shift well cover.
9. reinstall the shifter **** and boot.
Super easy.......
Old 05-14-2009, 06:11 PM
Mark Anderson
The Parts Whisperer
Actually I found some of those as well.
Old 05-14-2009, 06:14 PM
devilinblack
Used? The short throw shifter is on my "to-do" list but it's pretty far down that list. If you've got them for that price used I'll be down tomorrow at lunch to pick one up though.
Old 05-14-2009, 06:15 PM
Mark Anderson
The Parts Whisperer
Yes used for $42.
Old 05-14-2009, 06:16 PM
mark kibort
mark kibort's Avatar
ah, yes, there is a way. you need to mount the 85 gear box to the 78 and then use your existing shifter on the 85 torque tube and shifter linkage. cut the gear lever by 1" and you have short shifter. my 84 with the 85 gear box and torque tube was like this. It was sweet!
having a real short lever is good too, but it takes a lot of length to make up for the true way of doing this at the linkage area
mk
Old 05-14-2009, 06:19 PM
devilinblack
Yes used for $42.
PM sent.
Old 05-14-2009, 06:33 PM
svp928
svp928's Avatar
+1 on this mod- its definitely worth it. 928int'l has 'em..
Old 05-14-2009, 06:52 PM
Kevin Michael
Rocket Pilot
Kevin Michael's Avatar
Default short shifter
Mark, send me one of the used ones please.
Quick Reply: If you have a 5-speed 928 and don't have a short throw shifter; GET ONE!
