928 Forum 1978-1995
Sponsored by: 928 Specialists
How concerned should I be about this? (Welded Caliper Brackets)
Old 05-07-2009, 08:12 PM
Sailmed
Sailmed's Avatar
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
Originally Posted by Red
That's not something I would even consider gambling with. Sometimes people even give away the S4 spindles, but for $100-?, you could potentially save your car from being totalled or worse. Every time you come down the straight and slam on the brakes, you'll be thinking about it.
If you know someone giving them away - I know a leMons car that wouldn't mind a upgrade to S4 brakes.....
Old 05-07-2009, 08:13 PM
FlyingDog
FlyingDog's Avatar
It is very common to reweld spindles to fit different calipers or even just to space the calipers out for larger rotors. If the welds look good, leave them.
I'd rather have them welded like that than have the adapter brackets most people use...
Old 05-07-2009, 08:31 PM
heinrich
928 Collector
heinrich's Avatar
no way in hell I would trust that.
Old 05-07-2009, 11:16 PM
ivangene
Parts Specialist
ivangene's Avatar
holy mickey mouse batman !! - I would NOT drive with those at 5 mph!! Yea they might last 1000 years, then again - "CLINK" what was that noise!!
Old 05-07-2009, 11:33 PM
GlenL
GlenL's Avatar
Later spindles require the upper and lower arms.
If you replace those, send them my way.
Old 05-08-2009, 08:11 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
I have a brand new set of brake adapters with bolts for sale. I'll take $150 for them.
I paid $200.
Old 05-08-2009, 08:19 AM
LightStriker
LightStriker's Avatar
The weld looks really good and strong.
If done correctly, a weld can be stronger than the surrounding material. This weld look deep and clean and merge a lot with the surrounding. I would say the guy who did that knew what he was doing.
Old 05-08-2009, 09:11 AM
jon928se
jon928se's Avatar
Do we know if the car has been driven lots with the welded on adaptors ? If yes are there any cracks in the welds/parent material ? if not probably (I type that with caution) good to go. Would I drive it ? Yes gently until I had the opportunity to really test it then reinspect.
Old 05-08-2009, 09:40 AM
Ben
Ben's Avatar
I paid $200.
Hey Fabio,
Do these allow S4 brakes to run on S spindles, or do you need pre S spindles?
I'm looking for a solution to use S4 brakes on my S2 without losing ABS and without losing my current upper and lower arms.
Old 05-08-2009, 09:52 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
Originally Posted by ben12345
Hey Fabio,
They allow S-4 brakes to be mounted on pre S spindles.
Old 05-08-2009, 11:06 AM
FlyingDog
FlyingDog's Avatar
Originally Posted by Iccy928
The cage in this car is so nice... then I find this. I might be in the market for some S4 spindles...
If you replace these, let me know.
Old 05-08-2009, 11:17 AM
Rocketman928
Rocketman928's Avatar
The spindle is cast iron or cast steel - its a Porsche so its most likely cast steel...but its still cast. It has an irregular grain structure and is not even close to the strength of rolled or forged steel.
Welding a cast piece will work if the correct welding rod (stick or TIG) and heat prep is done for that specific grade of cast steel but most likely will not be stronger.
Just welding a piece of cast cold creates high stress beside the weld area.
The odds of the welder knowing the grade of the cast steel, has the proper training to heat prep and cool the welded piece and choose the right weld rod are not good.
Replace it.
Old 05-08-2009, 02:14 PM
svp928
svp928's Avatar
Rocketman, sorry to contradict, but the spindles ARE forged, not cast. No one uses cast iron for spindles, it just isn't strong enough, for all the reasons you gave. IF those bosses were welded on correctly, they are OK to use, but I would at least have them bead-blasted and magnafluxed... Not knowing how they were done, I would probably swap them out for peace of mind.
Steve
Old 05-09-2009, 12:17 AM
Rocketman928
Good to know - thanks
Old 05-09-2009, 03:40 PM
FlyingDog
FlyingDog's Avatar
I love how people who know nothing about race cars or common practices in building one feel the need to spew threats of liability and judgement about something that is extremely common. Rewelding spindles for different calipers is done regularly on Mustangs, Corvettes, BMWs, VWs, and even *gasp* Porsches! If done properly, that weld is stronger the early spindle/adapter setup many 928 owners use.
Quick Reply: How concerned should I be about this? (Welded Caliper Brackets)
