Murf SCer kit + Aluminum Rad (a la 928Intl) does it work?
#31
Rocket Pilot
First you say screen, now you say screens with some sort of "element" and now you seem to be taking a dump on Murf's product... I am beyond puzzled.
Those dyno numbers you list in your signature... very healthy. Are those before or after your modification? Sounds like before, otherwise you'd be pointing to a graph instead of describing seat of the pants dyno and a team of serious dudes that support this mod.
BTW - I sure wish I had your reduced horsepower problems, erh restrictions waving at me!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
#32
Administrator - "Tyson"
I do not care how Kevin runs his car, I'm just trying to advise anyone else from copying him.
#33
Rocket Pilot
I am not recommending this to any one else so no worries Erik. Mine pulled like a freight train to redline as well before. It is now pulling like a 747. Anyone who is not used to Murf 928 power and more of it would not notice the choke at 4-4.5grand and up. Try your car my way Erik, then reinstall. You will feel that bottleneck for sure. Stupid comparison so don't laugh, but when I dynoed that 552, my G-tech told me I was at 577. The point is I threw in bigger injectors and tuned the fuel, added the airbox mod, and the thing is telling me I'm at 638! So if it reads 25 higher than a real dyno, I might be at over 600 now. I'm not saying that's the case, but I will find out soon.
#34
Probably that same guy who as a kid said to jump off the roof with an umbrella in your hand, to see what happens.
#35
Rocket Pilot
Z, are you saying the airbox is not a restriction? I am not advocating its non-use, but please anyone with any sense can look at it and tell without testing it even it is a horrible restriction.
#37
As I said before, if somebody wants more power, there are proper ways to do it. Todd's car was over 700rwhp, even with his car having higher drivetrain losses due to the automatic transmission, and his car had an air filter.
#38
#39
It's nice to see the prodigal brother returns to rennlist.
#40
I'm not sure proclaiming victory because Randy stepped down and Gretch taking the helm is such a good idea.
This is like poking a bear at the zoo after climbing behind the safety barrier.
Good luck with that
Excellent
Good luck with that
Excellent
#41
#42
Supercharged
how about this stock one? http://cgi.ebay.com/ebaymotors/Porsc...3A1|240%3A1318
#43
Andrew,
If I remember I had to modify/change the following;
Shift the condensor forward by cutting the 2 mounting brackets shorter and re noching for mounting. AND also change the way the trans. cooler mounts, shifting it forward.
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02409Small.jpg)
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02412Small.jpg)
Shave off part of the lower rubber mount.
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02399Small.jpg)
Reshape the fan brackets and change the bolt hole locations.
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02400Small.jpg)
Cut off about 3/8" across the top of the air dam. Rad ended up sitting a little higher and the hood would not close.
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02417Small.jpg)
Also notch it
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02404Small.jpg)
AS you can see here it is a tight fit. I did have to eliminate the left and right air shields. (orginally black) With them in place I could not get the rad shifted to the front enough.
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02395Small.jpg)
In the end I am very pleased with the results. It looks good, and so far cools much better.
Since these photos I have changed to running 2 9" fans in front of the Rad. Its a much cleaner look, but I need to check the cooling difference this summer to see if it is the same as the 16" you see pictured here.
Hope this helps.
David
Also notch it
Hope this helps.
David
#45
Rocket Pilot
No, I am not saying that the airbox is not a restriction. It is a restriction, so is the filter. That goes for the screen that you've got on there, your radiator, and even the basic opening of the supercharger too. The goal was not to have a system with no restriction. It was to provide a safe level of boost that will put the car to around 500rwhp. The setup with the air filter and airbox does that. If you're goal is to remove all restriction at the expense of engine wear, increased detonation, and a more than likely complete engine failure coming up, removing the airbox is a very good start.
Thanks to the OP for sharing this thread BTW.
