Optimoly HT?
Anyone know a good sub. for Porsche's "Optimoly HT" lube? P/N 000.043.004.00
Local P. dealer wants $40.00 for 6 gram tube! Looks like gold, maybe is by price!
Thanks, John
Thanks, John
Former Sponsor
This is not going to be your most costly purchase, for your 928, I'm going to guess. Perhaps if you can afford the car, you can afford the proper lubricants....
I buy the real stuff to use on the hardware for my customer's cars....many tubes every year.
Team Owner
IIRC this lube is used on the splined stub shaft for the clutch disc/s.
Since most clutches stay in the car for many years it makes sense to use a good lube here so the splines dont corrode, ( this happens from sitting in a damp area)
Received 1,642 Likes
Optimoly HT is the stuff used on the clutch. It's been superseded by "Optimoly Olista Longtime 3EP" according to the WSM. It is a long-lasting high-pressure grease. If you dig hard enough you can find it on a Castrol web site.
There have been threads discussing this previously. But, alas, search doesn't find them.
One tube will last through many, many clutch jobs.
I bought a tube from 928 Specialists
looks like 928 specialists still have it but they want $20 to ship a $20 tube!
any other places to buy it?
I got the Optimoly TA (500g) from Castrol agent and the Optimol HT (100g) was a standard item from the parts department of my local BMW dealership.
Worth trying BMW dealers over there.
Here's a pic ...
Here's a pic ...
Just got a tube from Roger, with official Porsche labeling. A much more attractive stain on your hands than the silvery gray stuff. "Never-Seize never leaves" we used to say.
Chronic Tool Dropper
Never Seize hangs on until Dawn. Scrub your paws and duds with a good dish detergent to remove.
Most of the retail-market copper anti-seize is way too thin to work on the clutch splines. The axle splines are captive and non-moving (relatively) and would probably do OK with copper anti-seize from the parts store. But... how often do you have the axles out and the hubs off? I have little plastic bottles of anti-seize that are 20+ years old in my toolbox (in zip-lock bags BTW...), and I do use it on everything. A little goes a long way, it turns out. Don't be afraid to invest in The Right Stuff. You'll be happy every time you have to take something apart. Besides making that easier, it also eliminates threaded parts damage from galling.
