Torque Tube to Gearbox bolts - helicoil repair possible insitu ? Update YES it is.
Yes it has John.
Wether it was the TT rattling against the box I doubt. The only other things I have changed are that I repositioned the radiator top mounts as the radiator seemed very loose, and I don't have the rear undertray on (Got fed up taking it on and off to search for squeaks.
The undertray screws were all tight (replaced the screws and speednuts a while ago) but it's possible that the two self tappers that go into the chassis rails have partially stripped threads so that could be it. Don't fancy my chances of buying rivnuts and hiring the insertion tool on a sunday so welding a short stud into the hole in the rail might be the solution.
