symptoms of limp mode
#31
Yes, sorry for the misused terminology, Wally. I remembered it as being a pre-1989 ignition relay, but that isn't the case now that I look at the part catalog again.
It's a relay, though... I got that part right! :-) And it does bypass the ignition monitoring circuit. That's two correct answers!
Yes, I am aware that the ignition monitoring circuit is supposed to perform an important safety function, but mine was not behaving correctly - there was no problem with my ignition, but it was crippling my car. Can't have that...
#33
It takes very little time, actually. IIRC, you will need to remove the air filter housing to get a hand back there.
