928 Forum 1978-1995
Sponsored by: 928 Specialists
My ball bearings are black/blue........
Old 04-11-2009, 11:25 PM
Adam Geist
Adam Geist's Avatar
Default My ball bearings are black/blue........
in the rear axle shaft CV joint.
I'm in the middle of the axle rear axle shaft cleaning, grease repack and boot replacement. Both the inner and outer boots were torn but there was plenty of grease in there to be cleaned out. After cleaning, all 6 ball bearings in the inner joint are very dark in color - looks more shiny black than blue. The manufacturing date on the CV joint is the 35th week of 1986.
The cage and inner race show no signs of wear. The bearings are free of pitting or fretting. Should I continue forward with the grease repacking and boot replacement or replace the inner CV joint?
Thanks,
Adam
Old 04-11-2009, 11:40 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,587 Likes on 1,456 Posts
re assemble the CV joint per the WSM and with no grease see how much play the CV joint has, .
Your ***** may have gotten hot ( get yer mind out da gudder)as they are usually a silver polished color
Old 04-11-2009, 11:41 PM
AO
Supercharged
AO's Avatar
Leave it. If they fail, you're no worse off... except for the tow bil.
Old 04-11-2009, 11:48 PM
Adam Geist
Adam Geist's Avatar
The CV joint is reassembled sans grease on my kitchen island counter. I just checked my ***** (CV joint ***** that is) and there is no noticeable play or sloppiness between the inner race/cage/outer race.
Old 04-11-2009, 11:51 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
grease it up and put it in service, if it starts going bad you will hear it
Old 04-11-2009, 11:59 PM
Adam Geist
Adam Geist's Avatar
Will do. Just pulled the other axle shaft and inner CV joint from the parts cleaner. The inner CV joint ball bearings are bright and shiny. No noticeable wear in the joint either. Quite the color contrast from side to side!
Old 04-12-2009, 12:03 AM
jcorenman
jcorenman's Avatar
This may be a dumb question, please shoot me if so.
But if the joints look OK otherwise can't you just replace the *****? Aren't they standard sizes?
(The international standard of 25.4mm that is, I think bearing ***** are still standardized on fractional inches).
Old 04-12-2009, 12:12 AM
Adam Geist
Adam Geist's Avatar
Using an electronic caliper, both the shiny and dark colored ball bearings measured 22.28mm - give or take .01mm.
Old 04-12-2009, 12:42 AM
cold_beer839
cold_beer839's Avatar
The CV joint is reassembled sans grease on my kitchen island counter. I just checked my ***** (CV joint ***** that is)....
No way man, you got big phuckin' hairy ***** for doing that work on the kitchen island counter!!!
Old 04-12-2009, 12:53 AM
Adam Geist
Adam Geist's Avatar
Well, my now ex-GF is gone for the weekend. The kitchen island is the right height for working on tasks like this - the overhead lighting is a plus.
I did put down some heavy cardboard to protect the countertop before working on the axle shafts.
Old 04-12-2009, 01:21 AM
mark kibort
mark kibort's Avatar
those ***** dont get much action anyway (CV that is), especially if the half shafts are parallel to the ground.
Old 04-12-2009, 07:37 AM
Mike Frye
Craic Head
Mike Frye's Avatar
Adam,
I wish I'd known you were doing this yesterday I could have... Wait a minute, maybe this is something you were better off doing yourself. .
So it sounds like you made lots of progress, that's great. Will you be working on it today? The track meet I was supposed to go to yesterday was moved to tomorrow so I can't make it up in the am. How about today?
Old 04-12-2009, 08:36 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
is it possible that the CV joint wasnt correctly assembled in the first place??
I dont recall ever seeing black/blue ***** on a CV joint
Old 04-12-2009, 09:05 AM
Adam Geist
Adam Geist's Avatar
I'll take pictures and post later today/tomorrow. It doesn't appear the CV joint was previously disassembled - OEM boots and clamps.
Old 04-12-2009, 10:00 AM
Mike Frye
Craic Head
Mike Frye's Avatar
...must.... resist....urge.... to comment about pics....
Quick Reply: My ball bearings are black/blue........
