928 Forum 1978-1995
Sponsored by: 928 Specialists
What to look at while my oil pan is off
Old 04-04-2009, 05:55 PM
Stan.Shaw@Excell.Net
Stan.Shaw@Excell.Net's Avatar
Originally Posted by docmirror
My GT suffered a 2/6 rod bearing meltdown but it was on the track at the time under hard use. I agree that street use cars won't suffer. As for checking the clearance, you can use Plastigauge. I've used it before and it's pretty accurate. If the pan is off, I'd sure check it, doesn't take much time or money.
You do have to keep in mind that I am trying to avoid the pit I fall into each time. So many while I am in there, might as well do that. I have a 928 race car apart for 3 years now and my M3 street/track car apart for 2.5 years.
I am tempted to check 2/6 though...
Old 04-04-2009, 06:07 PM
David L. Lutz
David L. Lutz's Avatar
I used Plastiguage checking each bearing. I replaced mine with the yellow colored coded porsche bearings. (Porsche bearings come in three tolerance groups blue, yellow, red)
Old 04-04-2009, 09:45 PM
Roy928tt
Roy928tt's Avatar
If there is no knocking or lack of oil pressure issues, why on earth would you pull apart something that is perfectly servicable?
Furthermore if your pan gasket is leaking, wouldn't you check that the bolts are not loose prior to doing anything else?
If it ain't f#*ked, don't f#*k with it !
Cheers Roy
Old 04-04-2009, 11:33 PM
Cheers Roy
1. Because the effort to do so is nominal when you have already removed the oil pan.
2. In my case the bolts were checked
Old 04-05-2009, 02:18 AM
Ad0911
Ad0911's Avatar
Many people seem to have replaced the bearings or at least inspected them. Stan Shaw inspected the bolts. I was at a 928 technical day a local Porsche dealer lately where I asked the question if the rod bolts need replacing. They are stretch bolts. The 911 requires replacing them according to the WSM. The 928 WSM doesn't say that. The mechanic (a very experienced Porsche mechanic) told me to replace them. He may have said this just to be sure but there is no part# on the partlist. Any bad experience out there?
Old 04-05-2009, 07:02 AM
My bolt check was in reference to the oil pan bolts.
I don't recall the specifics, but the rod bolt (stud?) discussion has been gone over before and the consensus (as I recall) was they do not need to be replaced. Since the rod nuts are one time use, perhaps they "absorb" any stretch (guessing here).
Quick Reply: What to look at while my oil pan is off
