928 Forum 1978-1995
Sponsored by: 928 Specialists
Steering rack...you won't believe this
Old 03-31-2009, 11:29 PM
H2
H2's Avatar
Default Steering rack...you won't believe this
Last year, I was planning on replacing my leaking steering rack. I kept putting it off and it finally turned cold and I put it off until this summer. Knowing that transmission fluid is the fluid of choice in the 928 steering system, I put a bottle of transmission stop-leak in the system, figuring it couldn't make things worse. I can't believe it but after a few weeks the leak stopped. I keep checking the reservoir and it's always good.
I'm not recommending this to anyone but it worked for me...so far. If it starts leaking again, I'm just going to order a rebuilt from one of the big three or from AutoZone where (I've heard) many are rebuilt for them, et al.
H2
Old 04-01-2009, 02:50 AM
pcar928fan
pcar928fan's Avatar
WOW.... I have a little pin hole leak in my heater core in my '94 GTS and keep trying to figure out how to use the "radiator leak stop" stuff for that problem WITHOUT exposing ANY of the nice delicate engine components to the gunk... Have thought about using a hand pump to pump some of that stuff through the core with all of the engine stuff blocked off... then plugging the ends to leave it sit for awhile (day, week, month...whatever) then go back and pull all that out and flush it several times and then reconnect everything and see if it has fixed the leak...
Good call on the transmission fluid leak stop... Might try that on one or more of my leaky transmissions just before I have to change them out...just to see...like you said, it can't hurt and might actually put off a replacement.
Thanks for sharing that!
Old 04-01-2009, 03:03 AM
linderpat
linderpat's Avatar
Received 2,385 Likes on 1,294 Posts
Careful - good friend of mine and fellow r-lister used that stuff on his rad, and ended up needing a new engine. I would not use that stuff in my engine. Instead, find the leak and fix it. As to steering rack, seems like a decent way to extend life a bit.
Old 04-01-2009, 03:09 AM
bronto
bronto's Avatar
that worked on my steering rack for about 6 months, then it became a gusher.
Old 04-01-2009, 03:16 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
James: I have a used heater core from an 89 S4 sitting in my garage, if you need it.
Harvey: If you get a new steering rack, you might consider upgrading to the 91 and later type that allows for more power assist (in combination with a different pump and bracket. I would never want to go back to a pre-91 model for the power steering alone.
Old 04-01-2009, 11:53 AM
underdog928
underdog928's Avatar
I've done the transmission stop-leak (Valvoline) on the P/S system and it does work. I don't think you can do much damage to the system as it's only really making the seals expand and making them more compliant. Worst case you rebuild the rack.
As for radiator stop-leak, that is a much different (and scary) process. The chemicals in the radiator stop-leak actually plug the holes. Can't even imagine what that does inside the engine. Replace the radiator. I got a good used one from 928 intl (or buy Nicole's) and while your at it replace the water pump and flush the cooling system.
Just my 2 cents.
Old 04-01-2009, 11:57 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,205 Likes on 1,244 Posts
Three years ago I sucked out the power steering reservoir and filled up with a bottle of Lucus Power Steering Stop Leak juice.
Still drip free.
Old 04-01-2009, 03:48 PM
IcemanG17
IcemanG17's Avatar
My old rack leaked right at the bottom cover pictured above.....that and it had some serious slop issues....so I replaced it
Old 04-01-2009, 06:00 PM
SharkSkin
SharkSkin's Avatar
It's good that you've stopped the leak, just don't forget that the stuff that softened and expanded the seals in the rack to help them seal, will have done the same to the seals in the pump, and perhaps to the hoses as well. YMMV.
Old 04-05-2009, 12:20 AM
H2
H2's Avatar
Nicole,
Is the '91 steering rack a simple bolt-on replacement or does it require something else to make it work?
Sounds interesting,
BTW, I used Barr's Stop Leak in an old Chevy Pickup for 30 years. It had a leak that showed up every spring...then I'd put in a bottle of Barr's and it was good for a year. I always carried a bottle with me when 4-wheeling in the desert. But I'd never use it in my 928...Chevy engines are much easier to replace.
H2
Old 04-05-2009, 12:35 AM
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
I drove my shark for the first time today since September...apparently the oil leaks have clogged.
Old 04-05-2009, 03:11 AM
heinrich
928 Collector
heinrich's Avatar
Holy **** Dave ... WTF did you do to the Prez's pic??
Old 04-05-2009, 03:30 AM
Big Dave
Big Dave's Avatar
Those darn kids....the Off Topic forum is a tough place. Vandals!
Old 04-05-2009, 07:32 AM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Big Dave on ignore.
Old 04-05-2009, 03:27 PM
Big Dave
Big Dave's Avatar
Originally Posted by ew928
Big Dave on ignore.
Quick Reply: Steering rack...you won't believe this
