928 Forum 1978-1995
Sponsored by: 928 Specialists
Cam timing marks not what they seem? SOLVED!!!
Old 03-29-2009 | 01:30 AM
H2's Avatar
H2
I've not seen these cam timing tools before. Are there two in the set or four? Where are they available from? How much do they cost? Interesting posts.
Thanks,
H2
Old 03-29-2009 | 01:39 AM
blown 87's Avatar
blown 87
Rest in Peace
There are two of those.
Old 03-29-2009 | 02:03 AM
86'928S MeteorGrey's Avatar
86'928S MeteorGrey
Yes, there are two separate tools for cam alignment. One for bank 1-4 (tool # 9226/4)and one for bank 5-8(tool # 9226/3). They are included with the camshaft removal/instalation set which includes two of the tool # 9226 cam hold down clamps. I borrowed this set from Rob Edwards. THANKS ROB!!!
I don't know how much they cost or where you can get them, but there are plenty of people on Rennlist that will loan them out. The Rennlist 928 crowd really are a great bunch...
Here is a video of the whole set in action:
http://video.yahoo.com/watch/4629118/12377608
Old 03-29-2009 | 03:08 AM
blown 87's Avatar
blown 87
Rest in Peace
I could be wrong, but I think the later models need three of the cam removal tools.
Or maybe it was Porsche used to sell them in pairs and then split them up and did not change the price.
Old 03-29-2009 | 03:29 AM
SeanR's Avatar
SeanR
There is a later tool number for the cam removal tools.
For the 85-86 you have tool # 9226 and for 87+ 9248. Best to buy them in a set if you are going to work on either or.
Old 03-29-2009 | 04:07 AM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
9226 comes with the two cam holding blocks, 2 rods that thread into spark plug holes, and two cam lobe alignment bars. This set ONLY works on 85-86 cars- For an 87-95, you also have to buy 2 of the 9248 holding blocks, as the 87+ heads have these sleeves around the cam cap bolts that are larger in diameter than the holes machined in the 9226 holding blocks. Originally I only bought 1 of the 9248 tools, assuming that I'd get a pair of blocks. But each one only includes 1 block. And you still need to buy the 9226 set in order to get the mounting rods that screw into the spark plug threads. Live and learn....
Old 03-29-2009 | 02:07 PM
PorKen's Avatar
PorKen
Inventor
Originally Posted by 86'928S MeteorGrey
Also note that my cam sprockets are missing the extra holes shown in Zeus+'s cam sprockets outboard the timing adjustment screw locations. Mine must have been very early 85' sprockets. 928 105 530 00. For the interest of anyone else serching this topic, these cam belt sprockets were superceeded by 928 105 530 01.
The small holes line up with a cast pipe on the 86-up, 5-8/left rear cover. One of the holes lines up at TDC#1. Possibly used during factory assembly?
The cast nubs indicate the proper direction of the distributor rotor tip.
Quick Reply: Cam timing marks not what they seem? SOLVED!!!
