Paint sanding Vs Stripping
#31
An update: Mark has been helping me or should I say guiding me on the paint work. I am making progress he was over tonight and filled in the damaged rear. Car is getting closer.
#32
Just remember when patching your rear, the crack in the middle aids in body movement, and you have to make sure to leave a hole for your exhaust!
I'm sorry, I couldn't help myself.
#33
Update
Update on 85 Euro:
I have included some pictures of Marks car his came out beautiful, if I am doing things right mine should be right behind his. My paint booth is built, the rear has room for 6 furnace filters and covering will go on then the fan's.
#35
Stage one, 400 sanding then look for low spots, a little filling and a little more primer as required. I know for sure I don't want to paint cars for a living
#36
Use a guide coat to find the low spots. It will make your life easier. I would do a 600 grit wet sand with the next go round. 400 grit scratches can show through.
#38
How much did your 3M Dynamic Mixing set-up cost? Is there enough time saved, and convenience offered by using it instead mixing filler the old fashioned way? What brand of paint/primer are you using?
#40
Done With Sidepatch
I can't wait to see her finished. If it's anything close to the pics I saw of Mark's car you will have a show stopper!
Are you doing most of the prep (block sanding)?
#41
I"m the stripper and sander and have the fingers to prove it! It's a lot of work and I am a little too **** on this so it's taking a long time! I have sanded things that did not need sanding per 928tt, he is my mentor, I am the flunky in this project.
#43
Has anyone stripped the paint from the bumper covers? My track project has a cheap re-spray over the factory paint and I'd like to strip it away before applying new paint.
Tampa 928s, how did you guys handle the bumpers?
#45
ok, thanks. with the multipul coats of paint on the bumpers I'd prefer to eat away the upper coats with a chemical stripper first and sand second which sounds like it's am option
