No hot start, need fuel injector advice
Under the Lift
John hasn't been back here much but did post in February on another thread. I presume it fixed the problem as we heard nothing further.
Hello all, sorry for the late reply.
The new injectors did fix the problem. Before I started replacing the injectors, I could faintly smell fuel around the intake area. When I got the organ pipes off, I could see a wet spot around the base of one of the injectors. I replaced all of the injectors and I believe the o'rings that came with them fit properly. If I remember right, you need different o'rings for the 87+.
