Strange S4 cooling problem - New Pump Failure
#46
Dan
'91 928GT S/C 475hp/460lb.ft
#47
What Dan said except the 2 bolts that retain the bar dont hold the WP in place to the block; they screw into the WP casting.
Also, when you have a Porkensioner the idler pulley is no longer required as are the bar, bolts, screw and large boss pin the idler pulley rides on.
#49
Received 1,638 Likes
#50
Rest in Peace
Thanks Brother, my blood pressure went up 30 points in 10 seconds flat. ( I would post this here , but there is nothing funny about it to me)
but to answer your question............
Why, yes, I did contact them right after I found it out, and it is no one here, but some of the big parts vendors here may buy wholesale parts from them.
I told him if this block was ruined he had two choices, one would involve him finding me another good squirter block, and the second would involve me getting on a airplane to have some face time with him and the person that said "**** Greg".
This guy boss wanted to terminate my account with them because I had a problem.
Guess what, I now really do have a problem.
You guys do not know me from Adam, and I am not a keyboard commando, just stating what I feel I, or they, need to do.
It is not over yet, he said I would have to take that up with the manufacture, but after buying maybe 1/2 million in parts from him over the last ten years, I found that unacceptable.
We will see if it over heats this summer and go from there.
#51
Rest in Peace
To make my last post clear, the new, at the time, Lasso pump did not come from a vendor that sells 928 parts here.
I also want to say that I bought this pump before Worf had turned me onto this place.
I also have NO doubt if I had bought this pump from one of the vendors here, there would have been steps made to keep me as a happy customer.
I also think if I wanted to use a new type Lasso pump with the new design that any of the vendors here would gladly take my even newer rebuild pump with the plastic impeller back.
The whole thing just pisses me off, not that a part failed, these things happen, but what is important is how things are handled after the fact when there is a problem, and I have never had a issue with any of the vendors here in that regard.
#52
Greg, it's going to be iffy I think. The one I did the EBF to was, prior, about that and running warm-ish - consistently 10° to 15° hotter than it should have been.
Sterling? Did you read the whole thread before posting? Just askin...
EDIT: EBF was AFTER discovery of warm running.
#53
Rest in Peace
yes I read the thread.... I've had my 928 since 1997. I'm on my 3rd block due to stroker projects. I've installed no less than 10 timing belts..... due to tearing down the long block for one reason or another. Old school mechanics taught me that EVERY time you loosened the tenstion on a timing belt you replace the belt and the waterpump.... and EVERY time I have removed a timing belt for one reason or another I have replaced the waterpump. EVERY TIME... and one of the waterpumps was a new from the dealer waterpump with less then 3K on it... and I replaced it. In addition, to my car I have done timing belts on no less than 6 other cars.... and every time I refused to touch the car unless I replaced the waterpump. I was part owner in a shop where a customer gave concent ( with signature on the invoice) to replace the waterpump (knowing the cost) and after we tore it down, he refused to pay for a new waterpump. We refused to complete the job as he changed his consent mid repair. The other owner of the shop was the old school mechanic who refused to do a timing belt on a 928 without replacing every roller and taking the cam covers off and checking the cam timing with a dial indicator on the lifters. He has since retired but I carry with me to this day, his standards of repair and maintenence.....
I have no idea how many timing belts and water pump, rollers, etc all I have replaced.
I have no idea what it is you are trying to say Sterling, so I am just going to ask, what are you trying to say?
#54
Like Greg, I'm wondering what you are implying and what you implied originally and that's why I asked if you'd read the whole thread. Your first post into this thread seemed, upon first read, to imply that Greg was calling out a vendor, when in fact no where in the thread did Greg do that. Now, the way I read the above, you seem to imply that those of us that have installed water pumps, new Laso or otherwise, and had them fail in a few thousand miles are what? Imagining the block damage? Installed the pump incorrectly?
If I'm interpreting incorrect meaning to your post then please clarify.
#55
Well.... I've also had my (first) 928 since 1997.... and I've participated in just about all of the recent water pump threads and it seems, to me at least, clear that Roger IS in fact very concerned about the quality of water pumps, rebuilt or otherwise and acting on his concern. Furthermore, I didn't read any implication in this thread that anyone was blaming Roger for the failure of either of the water pumps and resulting block damage. That's why your first post into this thread seemed out of place to me.
#56
What exactly did Roger get done with Lasso? I ask because I was somewhat involved with this and I'm wondering what I missed?
Cheers,
Constantine
Cheers,
Constantine
I was just trying to say that this is an evolving market. It is always changing. at one point in time, the dealer rebuilds were the cats meow.... and then that was found not to be the case. And then the aftermarket rebuilds were in favor.... and then we found that was not the case.
I honestly believe that Roger has worked with Lasso to provide a Quailty product that we can depend on. The dealer would only replace the failed unit with another of questionable quality without promise to work with the manufacturer to make a better solution.... we have seen a number of rebuilds that failed and the question of quality stll remained...
Roger is working with Lasso to provide a quality part that evolves to make sure we get the best of the best....
That was my piont.
I apologized if I muddied the waters. I just saw the new post by Greg as a different viewpoint of the different problem......
That was my piont.
#57
Basic Sponsor
Hi Constantine,
To answer your question, I did not do anything with Laso other than bring to there attention the current situation with regard to failures of 928 pumps and the overwhelming desire by the 928 community to resolve the issue.
I also did the same with Porsches manufacturer (MPG IIRC) who refused to acknowledge there is a problem to start with.
Mark at 928 Int did a tremendous amount of work with the WP rebuilders to try and get them to change there ways but again to no avail.
Recently Laso have been modifying their design even further to incorporate a new impeller material that is not metal but strong enough to attach to the shaft without coming off. I do not see any of the other manufactures or rebuilders doing that.
What is also very important is that we continue to have these discussions and bring to the fore any issues we are having with products so we can make continued improvements.
Hope that answers your question Constantine!!!
#58
Thanks Roger! I remember our conversations about this topic and was hoping something came of it with Laso.
Wondering about the highlighted statement below. My company gave them a quote not too long ago about making the impeller from a material they specified and with the dimensions they gave us in their drawings. However this material did need a metal bushing. Never got a response back from them. Have they continued with this endeavor?
Agreed about the open lines of communications with suppliers!
Cheers,
Constantine
Cheers,
Constantine
Hi Constantine,
#59
Basic Sponsor
Constantine,
Somewhere in my notes or in the original "marketing" thread I did state the material they wanted to use.
I will dig it up for you if it is important. In simple terms it was plastic.
I know they were looking at the cost of tooling and allocating money in there budget to make it.
With the current climate who knows where that went 8>)
You pays your money you take your choice.
I am asked all the time about what is the best option and always try and answer based on what I would do.
For my cars I use a Laso pump. Just the best choice out there at the moment taking into account reliability, functionality and PRICE.
#60
Until this WP issue is resolved, I'm sticking with my low-mileage, rebuilt by Porsche in Germany WP. I'm trusting foreign technology from Germany more than most places (but not China, Bangledesh, and a few other places that Bosch seems to moving towards, including some shoddy US products...which (if you look closely) many traditionally USA made products are now partially or fully made in a cheap labor, variable quality control country. USA quality is suffering in many places too as companies who used to take pride in Made in USA are forced to have China, etc. make their products in order to keep up with the competition. And I won't even bring up the GM quality vs Ricer quality issue. Bad times and we'll have to search out reliable parts solutions if our cars are to survive.
That said, I guess I still don't understand why a metal impeller couldn't be drilled and pin-secured to the shafe in a failsafe mode...or an expert quickie spotweld wouldn't accomplish the same thing (that is one without chance of injuring bearings, warpage, etc....it has to be possible..no?. Admittedly, an alternation like this might affect trade-in value but that would be of little concern to me when you weigh the consequences of a failed WP.
Thanks to all those here who are exploring solutions.
BTW...where's PorKen on this issue?
H2
H2
