Front tire problems
The toe-in is to take care of the aft movement of the front wheels due to rolling resistance and air resistance while driving. You also need a little to compensate for any negative camber.
Supercharged
I posted up my alignment calculator and DIY video on the main DIY Alignment Thread.
https://rennlist.com/forums/6390423-post143.html
Ok, I will answer my own question now that I've tried it
One full turn (360 degrees) of the tie rod is approximately 2.1 degrees of toe. After changing my ride height, my car was 4.47 degrees toed in
Oh, and I was kinda confused as to why sin(x) from Jim's post was being used, then realized that the hypotenuse and adjacent lines are so close to each other that the error would be negligible. Still, to avoid confusion you should really be using tan(x) which will give you a 100% accurate value since you have the adjacent side and want to figure out the opposite using the toe angle (inv tan(x) of course to go the other way). I can't believe I still remembered SO/H-CA/H-TO/A from school
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
475hp/460lb.ftI used sin(x) since the radius (i.e. the tire diameter) was constant in this case. But you are correct that alignment calculations in general should be tangents, and also that for small angles it doesn't matter.
A toe error of 4 degrees? Holy tramline! Which way did you go with ride height?
Dan, thanks for answering that question, that's good info!
Dan
'91 928GT S/C
475hp/460lb.ft
