928 Forum 1978-1995
Sponsored by: 928 Specialists
Hood Vents?
Old 03-12-2009, 09:19 PM
  #61
Carl Fausett
Developer
Carl Fausett's Avatar
John, as you know, normally the area at the base of the windshield is high pressure at speed, hence the opportunity to use cowl induction.
But I have wondered about the recess in our cars before the windshield wipers... it is far enough away from the windscreen that it might actually be low pressure in that location at speed.
If I am right, then all you would need to cause more air to move through the engine bay is to remove the rubber seal at the top of the engine firewall. That would provide a pretty good gap between the firewall and the hood all the way across the car, and the air would escape out the windshield wiper recess.
I am reminded of my old stock cars days - lowering engine temps was as easy as adjusting the hood hinges to hold the hood 1/2" up at the rear.... same thing.... only in this case it would be stealthy and better looking.
At least it would cost nothing and do no harm to try.
Old 03-12-2009, 11:09 PM
  #62
Glenn M
Glenn M's Avatar
968 turbo shots in classifieds, interesting vent and intercooler.
Old 03-13-2009, 09:18 AM
  #63
Vlocity
Vlocity's Avatar
HTML Code:
I trimmed the middle out of that seal leaving about 8 inches in place on each end. I believe it works. As I mentioned the other thing I did to reduce underhood temps was to wrap the exhaust manifolds. I actually have the exhaust wrapped as well all the way to the tips.
Carl,
You need to build us a hood vent, there would be a market for those!!
Regards,
Ken
Old 03-13-2009, 10:07 AM
  #64
Vlocity
Vlocity's Avatar
I have been eyeing this vent, I just have no idea whether it would look correct and be in proportion.
Old 03-13-2009, 10:52 AM
  #65
Carl Fausett
Developer
Just got my May Excellence Magazine.
The Porsche RSR on the cover has a nice hood vent. (and canards!)
Old 03-13-2009, 01:11 PM
  #66
mark kibort
mark kibort's Avatar
Carl, no way! The high pressure zone is as wide as it is shown on the pressure graph plot. everthing around the windshield, the opening between windshield and hood as well as a few inches back is all HIGH pressure. verified with a sunx sensor, when i was trying to compare nose pressure to base-of-windshield pressure. the only thing a little lip before hand would do would be to reduced the pressure zone, but it still would be positive pressure, unlike the middle of the hood where there is low pressure. the entire a/c area is high pressure. if you open the rubber seal, as I have on my car, you would be forcing air into the engine bay. AND, in my case, forcing air into the air box, as I have it ducted to it via a rear air box vent. If you, or anyone saw lower engine bay temps by doing this on other cars, it was probably taking the above hood air flow, raming it down the engine opening and venting out the bottom. (creating some lift). not a problem for most all street cars, but if you are doing track events, open road racing, or want to increase downforce, that isnt the way to do it.
mk
Old 03-13-2009, 01:21 PM
  #67
mark kibort
Ive always wondered about doing this. (wrapping headers) . its supposed to keep more heat in the exhaust, to reduce restriction. also, keeps the engine bay cooler. dont see it too often at the track though, and I wonder why. hassle factor. can you imagine trying to do a 928 header wrap with the headers on the car????? ahhhhhhh!
mk
Originally Posted by Vlocity
HTML Code:
Carl,
Regards,
Ken
Old 03-13-2009, 01:36 PM
  #68
Lizard928
Lizard928's Avatar
Mark,
Header wrap works, but before you do it you MUST ceramic coat the headers or the wrap will shorten there life. As well it is NOT cheap!
Old 03-13-2009, 03:41 PM
  #69
mark kibort
oh, they are coated , but wraping them would be a tough job on the car!
Originally Posted by Lizard931
Mark,
Old 03-13-2009, 04:39 PM
  #70
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,174 Likes on 1,229 Posts
Old 03-13-2009, 04:55 PM
  #71
mark kibort
very cool shots! two of them running WCGT this year?? what was this event where the pic was taken. some kind of promo day? test day? I notice the touring car in the background from Bmmerworld.
edit: Race next weekend! This should be a good one. Sofro in the GT3 porsche with Curren and Davis in their V8 monsters vs the other rookies. Not many big names left and the field is kind of small. But, there are the 2 new volvos with pobst and pilgrim running. Tourng is a disaster, unless there is some late entries. 8 cars officially signed up with 5 more to put in names. If realtime racing pulled the plug there would be an 8 car field. hardely TV worthy. They should give our ITE SCCA racing some TV time. 60 car fields, more diversity and closer racing! ha ha
mk
Originally Posted by Hacker-Pschorr
Old 03-13-2009, 05:06 PM
  #72
DR
Rennlist Sponsor
DR's Avatar
Even the Street Version has the forward radiator vents AND the rear "engine/exhaust" Vents. Best version I have seen yet that would look great on a 928, even on a street 928.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 03-13-2009, 05:22 PM
  #73
mark kibort
dont know what the aero of the aston Marton would look like but the front vents surely are radiator flow vents. the rears, i was looking for a few months calling dealers for replacement parts so I could use them on my mod. i couldnt find them. so, i ended up with some of the best looking raw alumininum mesh I could find. those vents are great looking on the Aston though and would look great on the 928
mk
Old 03-13-2009, 05:41 PM
  #74
Mike Frye
Craic Head
Mike Frye's Avatar
hmmmm. I've got a spare hood....
I bet you wouldn't even have to worry about rain going in there. It would only go in when you're stopped, so it would drip right down behind the fan. Maybe even put a bit of a scoop on the underside of the hood to direct the air up and any rain water down and forward...
Old 03-13-2009, 05:45 PM
  #75
hacker-pschorr
mk
Did you see the other Aston engine shots I posted showing the aluminum foil looking devices funneling heat from the headers up to those vents?
Quick Reply: Hood Vents?
