Hood Vents?
#31
No, your are right. maybe i wasnt explaining it clearly. the add on vents were to route the air over the hood to keep the air from normally going under the car as it passed through the radiator. the little bump in the vent couldnt take a higher pressure zone like at the base of the windshield and create a lower pressure zone. It could reduce the pressure, not enough to change the direction of flow.
Lets not talk about he "50" thing!![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Mk
Mk
#33
Owns the Streets
Needs Camber
Needs Camber
VENTURI!
Remember the blowing air over across top of straw sucking water up the straw physics experiment. Airflow over opening is supposed to pull air up through it.
Stole this diagram from M. Kibort's post.
Nice low pressure zone around the top of the front wheels.
![](https://rennlist.com/forums/attachments/928-forum/266512d1206629030-hood-vents-airflow-help-928-aero-curves.jpg)
Interesting how the front of the sunroof is at peak low pressure.
#34
Rennlist Sponsor
Oh Ernest, I was trying so hard not to mention the "unmentionable word"..
There goes the neighborhood.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
#35
John, does your car still have wheel-well liners in it? If not, some vents above the front tire help a bit with front downforce. Since your car is a track-only, you may think about putting a vent where the sunroof used to be, about 1/4 the size of the old panel, biased to the front. I think it has to netted so no parts of your body can come through. They like all driver body parts to stay in the car, so they don't have to hunt around for stray bits.. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Since you are using the base of the windshield to take in cold air, you want your hood vents toward the outside edges of the hood...the hot air then flows off the sides and comes back into the cockpit, roasting the driver on its way out the sunroof vent... but it makes some downforce, so thats worth it, eh?
I've been planning to do these things to my own car, but it would be cool if you tried it first and let us know if it works...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Maybe think about a Cool-Suit?
Steve
Steve
#37
Some vette racers literally take a cutting tool and cut vents directly into the hood. Works well for them - also reduces front end lift. (So they say)
I would say 1.5 wide - 6" long (3 or 4 on each side of the hood) - about 1" off the center of the hood and about half way back from the front.
YMMV
YMMV
#39
Thank you all for the great ideas and discussion.
Guess its time to start cutting!
Good thing I have a spare hood to practice on
#42
Craic Head
#45
Man of many SIGs
