AC always on
The wire runs from the freeze switch to the CE panel, in there it splits off to the W24 terminal on the panel(LH) and the M21 terminal, which then goes straight to the low presssure switch then from there through the 14-pin connector and to the compressor clutch. If you're not getting 12V switched via the AC button at one terminal of the low pressure switch, then the wire betweeen there and the CE panel s the problem.
I understand that you don't want to open a can of worms digging into the charred harness, but IMHO that's what you have to do. There could be other problems waiting in there.
I obviously had the wrong wire activating the compressor clutch. Remember you pointed out that the green wire was not supposed to go to the compressor? So now I need to find or fabricate the correct one...
As others have said...if the system has no Freon and all is working properly the clutch will not engage. Its running all the time because its jumped....thats bad! Un jump it, replace the dryer and pull a vaccum...If it holds overnight then charge it and see what happens.
Ok, let me run this by you all, let me know if I understand everything correctly. With ignition on and ac button on I should:
1. have power on both terminals of the freeze switch
2. have power on one terminal of the low pressure switch
I do have all of the above conditions.
I have no wire going to the compressor. Should I use the black wire of the low pressure switch ( one that does not have power right now) and run it to the compressor? Is that not the way the system was set up to work originally?
Yes, you have it right.
The wire to the compressor should be a black wire(Schwartz is German for black, that's why the wire diagram the DR posted says "SW" fo rthat wire). It should go through pin 9 of the 14-pin connector as shown on that diagram.
An excellent time to replace every O-ring in the system, or at least every O-ring that you can get to. These are the most common leak points, and it would be nice to have new rings that are good for R-12 or R-134a.
Every joint is sealed by an O-ring. If you call Jeanie, she can send you a kit of all of the correctly-sized O-rings of the correct material. (828) 766-9280
I don't think its a pressure issue - you need to ensure you fully evacuate the system & fill to the correct volume/weight for your model year & configuration (front only or front+rear).
Pressure will vary when its running & based on temperature etc & without it running you will have uneven distribution.
Alan
Alan
