Snapped linkage, not ball cap ...
I would give Mark a call , I am pretty sure he has some.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Rest in Peace
Late style shift lever on left, early style on right. Note "pin" spacing.
explain how that works? I dont think the length does anything. its the lever pin spacing that determines the throw, as well as the levers in the gear box. thats why the newer transmissions with the older levers make for a real short throw system. (more than just the lever itself, based on the 84 lever spacing being longer than the s4 spacing)
mk
mk
I only did this because i didnt want to drop the torque tube or exhaust. Thankfully, Bailey advised on cutting through the foam insulation and removing those 2 10mm nuts from above. it worked like a champ and was able to remove the shift rod and replace it with everything on the car. very tough to get it up in position, but eventually, it was up in the position. the rest was just normal mounting with the hose clamps used as a press for the ball cup, and a little hatch cut out to reach the 2 10mm nuts easily from above. (near ash tray area)
1st shot is how I got home. next pictures is the bolt I welded in the shaft to bolt it to the broken part. it would have worked, but wasnt counting on the extreme axial loads that weakened the small bolt. I turns out its just easier to replace the darn thing with the real deal.
mk
mk
so, i have the straight rod on mine but it was fabricated from a automatic, so who knows what is right for the year. I think i remember my 84 having a straight shaft there too. when did they change from the bent rod near the gear shift end?
If you need the bent rod end, I have one as that wouldnt work for my set up.
however, when i transfered the 85 transmission to my 84, there was no mods needed to the front shaft at all. althought i think i do remember using a later torque tube when i changed the transmission. its all a blur.
mk
mk
Yep, seen it before. In this case it was caused by a mechanic taking a short cut and trying to use the early style shift linkage when installing a late style (85-up) tranny.
You would think after it broke and had to be rewelded in the first few days that there might be an issue. Unfortunately they keep using it this way and it caused some "shifting" parts inside the tranny. We had to open it up and fix it. GRRRR.
You can see the results of doing this in the pic below, the lower shift rod is the "abused" early shift rod. If you look close you can see where it was welded at the same place. This was welded ON the car from the inside...SCARY!
Rest in Peace
My bent rod is now fixed and appears to be standard for an OB.
My puzzle about the hard throws and blowing out the forks, is that not driver error or hand resting on the shifter?
mine broke the shift cup as I was constantly pressing my gear shift **** on the shaft. it weakened the ball cup attachement. the shaft broke due to the same forces, plus the ball cup not adjusted properly and addign torsional forces in the 5th 4th range.
I dont see how the shift fork can be damaged, unless you really are pounding the gears and going past the point of engagement.
mk
mk
