Flywheel Skimming
#31
OK, got it. Have you heard of anyone machining the PP surface? I'm sure it's possible but I don't see how you would positively position it, since the best you could do is clamp against the rear face of the fingers. Since those are stamped then heat treated, I would think that it would be a bit tough to guarantee that the PP face is parallel to the fulcrum.
#32
The benefit to doing so is reduced vibration and increased rear main bearing life at minimum.
#33
Paul
This could be a possibility , your own flywheel ground till cracks are gone & then an insert fitted ? (at least I think thats what they do )
http://www.clutchnet.co.uk/12.htm
