New Product - SHARKVENT Crankcase Ventilation System - NO more Oil in your Intake!
#46
Rennlist Sponsor
I'm lost, can you cut and paste what you mean?
The last pics I posted are the X version, look at the Graphics on the 1st page of this Thread.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
#47
Rennlist Sponsor
Brian,
I think I know now what you are talking about (please correct me if I wrong).
In the first photo in my initial post the X version shown has a 1" Tee and then a 1" to 5/8" Reducer going to the cam covers. That was the first install. Since I had to get the uber expensive 1" aluminum elbows to make the special fitting for the 16V engine I decided to use those and upgrade the 32V X systems. It costs me more but it gives a sleeker look, flows better, and a simpler finished product . Instead of a large 1" tee and then a 1" to 5/8" reducer in line with each other I now have a 1" custom elbow with a 5/8" port on it.
The photo below shows the 1st X version (on the left) and the revised X version (on the right) and may help explain better. The custom fitting is shown below the pics. IMHO it makes the system more refined and it also streamlines the oil vapor flow from the filler neck into the ProVent since the smooth long radius elbow flows better than the "no" radius Tee fitting.
#49
Rennlist Sponsor
Cool, now I get it.
Those are the oil return/drain assemblies that attach to the bottom port of the ProVent.
On 89-95 they do not have the removable plate on the oil pan like the earlier 928s. That is why we have to use the modified dipstick as the oil return on the 89-95. However if you happen to have your 89-95 oil pan off it is better to drill and tap it (1/4" NPT) and use the 88 and earlier style return.
#50
Rennlist Sponsor
Brian,
FYI, here is a pic showing where the removable plate is on the 88 and earlier oil pans. In 89 they no longer milled the hole and eliminated the plate. This was left over from the 16V engines that had the oil return pipe mounted to the oil pan.
EDIT: I added another pic that shows the later style oil pan with the plate ommited.
#54
Hi Colin,
I did a lot of testing with that on my SC systems and found for me it wasn't worth the hassle. If anything I feel the drivers side should be vented as a fresh air intake due to the rotation of the engine.
However, as you can see from our GTS SharkVent (see graphics and GTS protoype photo below) we accomodate the drivers side vent (it's hidden under the fuel rail) in the system and that extra T fitting can be added by request to any of the other SharkVent Kits.
Would it make sense for the GTS breathers to move the hose from the front of the drivers side cam cover to the back and ad an oil separator under the cam cover (like the one on the passenger side)?
What about two breather hoses on the drivers side for maximum breathing?
Is there room for an oil separator under the cam cover on the front connectors?
#55
#56
Received 1,603 Likes
#58
Rennlist Sponsor
Hi Dave,
I have had a few requests for a version for the Murf Kits and I would be happy to do it. I have already made a couple of custom MAF-LOC Kits for a few Murfers. All I need to do is get my hands on someone's 928(with a Murf kit installed) for a day and can work out the different hose layout and mount. If I don't get the chance before SITM, I am sure I will have the opportunity then.
Tom F. has his ProVent mounted back near the MC on his CS install and said it is working great.
#59
David,
I just order the x-treme one for my 88 S4 yesterday. I do have a Murf stage 1 super charger sitting at where Pro-vent will be. Should I wait for you to put out a kit to reloadcate everything?
#60
Rennlist Sponsor
Looking at some of the Murf Pics I think we can mount the Provent on the drivers side fan bracket. If so, it is just a simple matter of different hose lengths. If we can do it there the Oil return to the oil pan will be perfect.
Judging from a pic David posted in another thread it looks very doable.
![](http://i267.photobucket.com/albums/ii310/lutz928/porsche/PorRad/DSC02414Small.jpg)
