New Barnard Racer uses 928 twin turbo motor?
"The development car is powered by a twin-turbo Porsche V8 cranking out 617 horsepower."
Pretty cool to see them use a 928 motor.
http://www.autoblog.com/2009/02/23/p...rom-south-afr/
Administrator - "Tyson"
Wow - that's awesome!!! A 16V no less.
I wonder if this group is tied in with the 928 body kits presented a while back, those were also from South Africa.
Looks a lot like a 928 transaxle notice the shifter linkage. The webbing on the rear diff housing. They just eliminated the torque tube. Sure looks like a fun ride. I wonder how the $100,000 plus market would accept a 30 year old engine and only a 5 speed ?
I know someone that will be a good sourse for replacement parts. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
That seems kind of insane. Big dollar supercar, using 30 year old engine.
What is it doing for oiling issues??? crank, pistons, etc etc. is that block even 928 or something else?
from the pic in high res mode, it does look to be the 928 block, but hard to tell.
Remember this one?
Remember this one?
928 OB-Wan
I hadn't seen this one yet, interesting combination
there have been a few cars (mostly turnkey to semi-finished kit) the last few years with a similar concept
most I've seen utilized a chevy engine mated to the G50 trans, 1st I've seen a 928 engine, though I did mention it as a possible powerplant to a few "builders"
the G50 trans will hold about 600hp, a G50/50 will hold well over 800hp IIRC, though finding a 50/50 is near impossible and likely to set you back $7-12k
be interesting to see the final version
1 Post
Sorry to dissagree, but I reckon that it is a 928 gearbox, 911 Gearboxes in this installation have the gearbox behind the driveshafts, as I recall. Also I'm curious about the advertised horsepower, 617 hp, I see no evidence of intercoolers, I would expect you would some sort of charge cooling for that sort of output.
Still, interesting choice of power plant/ driveline
Cheers Roy
Cheers Roy
Cheers Roy
Cheers Roy
I honestly question why you would use a M28 in an all out race car. The damn thing is HUGE, and very very heavy for a tubeframe race car. The M28 weighs about 550lbs, a small block chevy apparently is in the 350lb range. Cant say i suggest a 928 engine for racing......
I did also notice the BMW coolant reservoir
