Cleaning out the garage - 928 parts FS
Road Warrior
Spring Cleaning Time again. Have some left over goodies from winter projects.
All parts originally from my 85/86, but may fit other MY also.
Edge Racing Torque Converter. Fits 85-86, may also work on later or earlier 928s. New, Still in the box - only $250.00/SOLD
OEM/Stock Front sway bar with 928 SP HD greasable mounts. clean, includes drop links and all rubber, ready to bolt on. $100.00 - available
Rear Adjustable Droplinks from 928 SP. New, set of 2. $55.00/SOLD
would prefer socal sale, but will ship if needed. shipping not included in prices.
Dibs on the sway bar
PM sent.
PM sent.
Road Warrior
yes it is a stock sway bar. good condition, the droplinks/rubber and w/the 928 SP mounts ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
from my winter/post AX season project list - a 928 MS GT2 Ultimate sway bar. cost $600 for the bar/kit, another $1200 to make it fit right, another $250 to reinforce the mounts... it's now a 2k setup that was supposed to take "2 hrs in a driveway" to install. OTOH, it is amazing in action and looks great now too.
Road Warrior
No worries Sean... I made the OP more clear on that point. only thing I could offer to help w/the hair trigger is to think of an STD, pissed off MIL, gay pride and expensive spoiled kids while having sex... might slow things down a bit, hahaha...
Man of many SIGs
I'll buy the rear adjustable drop links. I assume these are the "red" steroid link 928spec used to sell.
I'm not local but my money's good.
PM sent. Thanks.
Road Warrior
silver... came with the red HD Rear 928 SP Sway bar, but I used custom droplinks for that because I was on a rampage.
I've bent stock drop links 2x. these won't do that for sure, and you can adjust them to insure they are even on both sides...
Road Warrior
You guys are mean, but I deserved it. heh.
Could you please expand on this!
Road Warrior
I'll have to take some pics.... the 928 MS bar and arms are excellent quality and look great, car handles flat like a go cart almost, and that's just on the "soft" setting. doesn't hurt ride quality, but sure wipes out body roll a LOT more than the HD rear does on its own.
U have to reinforce the main bar mounts, or they'll tear out of the car eventually, due to the increased stress... easier to do before any damage occurs, so I had that done 1st.
kit came w/some drop links and HW. never could get that stuff to work out cause the angles were too tight, caused binding and even rubbing on inside of wheels (18x8.5's, forgot offsets, but they handle 265/35's nicely). also drop link ends were loose on shock bolts, needed lock nuts on both ends of the drop links instead of just 1 end. minor stuff but made it noisey/ a bit sloppy and started to mangle the front wheels before I figured it out.
had greg brown get some different link ends, make some spacers, got LH lock nuts slapped on and it's all good now.
fwiw, I don't think I've ever seen aftermarket stuff for anything (bikes, cars, trucks, etc) ever be 100% easy to install w/out some tinkering/adjusting/fab work. but some stuff takes more effort. for such an "easy" bolt on, this one was a bit more of a bugger to sort out than anticipated, imho.
but it's ready to rock and roll for AX season/should be a hoot
