Injector resources and questions
Group --
Two injector resources that you may be interested in and then a question.
First, here's a catalog of most all fuel injectors know to man. It will not answer all your questions, but it can be used to rule out some definite non-matches. I don't think I've seen this resource posted here yet, but if someone has already done it my apologies:
http://users.erols.com/srweiss/tableifc.htm#tabtop
Second, in case someone is thinking about making their own intake manifold, here are some injector bosses that are available both in aluminum and in steel. The look pretty cool and should weld reasonably easily to a runner:
![](http://www.sdsefi.com/newboss1.jpg)
They aren't cheap, though. $40 per boss plus shipping.
Now, then to questions. I've read most if not all injector threads on the forum. There's a lot of info about replacement injectors. However, I would like to know more about the largest injectors that people are succesfully running with the LH computers. So far, I've found short Siemens Deka high-impedance 60 lbs/h and 83 lbs/h injectors that might work. However, I'd very much appreaciate any comments based on actual experience with very large injectors.
the injector boss is very simple, those look overly complex, very large and would lead to a very high profile fuel rail
Actually, i am looking for a low profile injector, something like 2/3rds the height of the current 928 injector. Do you see anything matching that description in their product line?
The shorties are in some fords and chevy cars and trucks.
How does the shark tuner work with twin mas air metering devices and twin throttle position sensors?
I know the twin screw setup by DR does this, it is critical to my intake design, im just not exactly sure how the LH handles the signal when it comes from a pair of MAF's and TPS's
So the short Siemens Deka #60 high-impedance injectors would work with the reprogrammed '87 fuel computer? My guess is it would. Given the manual transmissions we're forced to live with, I don't think the #83s are necessary.
Yes, I believe they would be OK, at rated fuel pressure.
would you also use 2 TPS switches, or since they would be linked to the same cable from the throttle pedal, you would really only need one TPS sensor reading off a single throttle body?
MAF1 -> resistor -> output terminal <- resistor <- MAF2
Wouldn't this about "average" the two signals voltages? I don't think this MAF signal has to "drive" anything so maybe this would work.
See http://www.allaboutcircuits.com/vol_3/chpt_8/8.html
If the plenums are connected at some point, the LH / sharktuner should then function as before.
Completelymisunderstoodthisagain?
Chronic Tool Dropper
I think you need the SUM of the two airflows, not the average. Your average signal would give you half of actual total Assuming that they are both passing exactly the same amount of air, then doubling the 'average' would hardly be the right way either. I'm sticking with SUM, final answer.
Now, as you correctly point out, with stock maps the computer feeds in only half the fuel. But the map can be changed to feed in more for a give MAF signal level.
Effectively, the hardware is fixed to accept 0-5v, but that can then be internally mapped to whatever desired by changing the fuel maps.
