ABS looking for links how to repair.
Rennlist Site Sponsor
The Morehouse CD set includes four different ABS test plan and troubleshooting booklets, along with a great deal of other pertinent info.
jim928-at-ptd.net (change -at- to @)
Under the Lift
I just noticed a few days ago that when the interior light fuse blew in a GTS I was working on, the ABS light in the dash stayed on all the time until I fixed the interior lights and replaced that fuse.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I had severed wires on the front wheels of my ABS system. The heat from the engine combined with weather destroyed the wire sheathing causing ground outs, and breakage due to rubbing on suspension pieces. This was also because it was not mounted correctly.
33, 51, 85, 89, 92861810203, 92861810400, 996, abs, connection, controller, corvette, flasher, ground, jdsporsche, part, porsche, relay
