A/C flush and retrofit
Hello,
I’m getting ready to attempt fixing my ac. Here is the story: The ac lines got burned by an engine fire a couple of years ago and I never got around to getting anything fixed. I just got the rubber that got burned replaced by a hydraulic shop and back on the car. My questions are:
1. I realize the dryer needs to be replaced
2. Expansion valve needs to be replaced. (I have rear air does that indicate that I have another valve somewhere?)
3. I’ve heard it’s best to flush the system, what is the procedure for doing that?
4. Does the compressor need to be flushed or is it supposed to be disconnected from the lines when it’s done?
5. Rubber o-rings will be replaced too.
6. I’m planning to switch to r134 what oil and how much of it should I use?
Thanks in advance! The car is a 1986.5
Hello,
To evacuate the system, use a proper vacuum pump (2-stage) to pull a vacuum for at least 45 minutes to make sure all the water in the system boils off.
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Can you get these vacuum pumps for the garage? Or do you need to go somewhere?
Dan
'91 928GT S/C
https://www.ackits.com/pc/90066/Vacu...ge+Vacuum+Pump
Dan
'91 928GT S/C
I would suggest that you refrain from using mineral spirits as it leaves a residue in the system. There are dedicated flushing solutions available at the parts store, usually right next to the refrigerant. They're solvent based but leave no residue. All you need to do is give it extra time on the vacuum pump to make sure all of it has evaporated. The stuff also smells better then mineral spirits.
The valves should be removed for flushing and then replaced with new ones.
Use ester oil.
Brendan, I got a 5CFM Robinair from e-bay for $165. Several people sell them.
Use ester oil.
Use ester oil.
Use ester oil.
Dan
'91 928GT S/C
Use ester oil.
Use ester oil.
