Central Alarm Question
Anyone know how to make the alarm go off? Strange question I know. I read the manual and it just says after the car is locked any attempt to open the car without the keys will set off the alarm. Well, the car is new to me since May '08. The lights in the door lock stems flash as though the alarm is set. If I just try to open the door without the key (i.e. pull up on the handle) nothing happens. Just curious as to whether my alarm is actually operational or not...
(hoping I don't have to jimmy the door to test the alarm)
Dan
Dan
Hello Aryan, mine's an 87 S4. I've been trying to get the alarm working, is there a light somewhere that flashes to indicate that the alarm is armed? I'm thinking that the alarm control behind the glovebox is toast.
I don't know from own experience, but not according to this thread https://rennlist.com/forums/928-foru...f-you-can.html. There is some further info on a short and long key, maybe that helps.
Rennlist Site Sponsor
I assume that you mean that the alarm didn't...
Try again, but this time reach inside and open the hood. Try the passenger door.
If one of these work, the problem is likely to be the door open switch.
To test the door switches, open the door and with a screwdriver, engage the latch. Hold down the switch in the door jamb, and arm the alarm. Once armed, release the switch in the door jamb. Don't forget to release the door latch before you try to close it!
Dan
True; I guess I'm thinking that in order for the alarm to be set all door switches (drivers, passengers, hood, rear hatch) must be behaving as though they are in the closed position (whether they are or not). Once the alarm is set any opening of a switch results in the alarm going off. It should mirror the interior lights behavior I would think. I guess if there is a short circuit in the alarm wiring prior the door switch where the positive and negative leads were crossed that would bypass the door switch and give you an always closed position regardless of the door switch--seems crazy but then anything electrical is possible in a 928. I'll give the door switch trick a try and report back sometime.
With the doors closed, the line to the lights and alarm is open circuit, it gets grounded when you open the door. So, if someone cut the wires between the alarm and the door switches(in a manner that leaves the lights working) the alarm should still arm properly, but not trigger when a door is opened.
Probably no big deal either way, especially if you're careful about where you park.
Electron Wrangler
Try this - open both windows, lock the car. twist the inside unlock **** for the door lock - does the alarm sound? try both sides. Its primarily the unlocking that triggers the alarm for the doors.
The things alarmed on the late model cars are the door locks, door pin switchs, hatch pin switch, radio frame L*, radio frame H, glove box, Expansion 1 L*, Expansion2 L*, Expansion3 H*
* These exist but are not typically used on production models.
Alan
Alan
