928 Forum 1978-1995
Sponsored by: 928 Specialists
More base circle questions
Old 01-30-2009, 02:47 PM
  #46
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,221 Likes on 1,253 Posts
Originally Posted by FlyingDog
What about modding the hydraulic lifters to be more solid?
Fill them with JB weld?
Old 01-30-2009, 02:49 PM
  #47
FlyingDog
FlyingDog's Avatar
I was thinking more along the lines of restricting oil output or stronger spring inside.
Old 01-30-2009, 03:11 PM
  #48
Dennis Wilson
Dennis Wilson's Avatar
Or pull the hydraulic mechanism out and install a case hardened plug.
If there is no abnormal wear, once set there shouldn't be any adjustment required. The only exception would be if new lifters and cam were used, the breakin may put the lash out of tolerance.
Dennis
Old 01-30-2009, 03:16 PM
  #49
RicerSchnitzzle
RicerSchnitzzle's Avatar
Originally Posted by BrendanC
I had forgotten about lash caps. But they are usually pretty thick, relatively.
That's why I was saying "Shim", most lash caps I have seen are .060 or .080" much more than 1mm or even .5 mm. We would need .020-.040 to be in the range of a base circle reduction. Then you still have to match up valve stem diameter.
Wonder if someone like Lindsey Racing makes a 944 lash cap for solid lifters that would work for us? Back to google I go.
Old 01-30-2009, 03:21 PM
  #50
Dennis Wilson
There was a central purchase of solid lifters for the 924 crowd recently at www.924board.org . May want to check the thread for sources there.
Dennis
Old 01-30-2009, 05:12 PM
  #51
Dennis Wilson
A better link for the solid lifter group buy from Piper is as follows:
http://www.924board.org/viewtopic.php?t=24727
Dennis
Old 01-30-2009, 06:23 PM
  #52
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Early 911 engines are "solid" ..They need to be adjusted every 6,000 - 15,000 miles depending on who you believe and much more often on a race engine . The 944 GTR turbo 650 HP 2 valve per cylinder special has windows in the cam housing so you can reach in and check clearance. HOWEVER if the lash caps adjustment needs to be changed you must pull the camshaft ! Since they almost NEVER finished a Transam race they were being rebuilt and shimmed a LOT !
Old 01-30-2009, 06:27 PM
  #53
RicerSchnitzzle
Vacmotorsports.com has 1mm lash caps in 6-9mm diameter size. Double checked with Delta and itls $125 a stick for a base circle reduction, though I may be able to grind them down on that..
Need to see how the oil passage lines up with the bucket being 1mm higher when the valve is closed.
Quick Reply: More base circle questions
