928 Forum 1978-1995
Sponsored by: 928 Specialists
Stop Lamp Warning Question
Old Jan 25, 2009 | 07:37 PM
Greggles's Avatar
Greggles
Default Stop Lamp Warning Question
When the car is started the stop lamp warnig light comes on immediately.
If I step on the brakes the light goes off and doesn't come back on.
All of the bulbs are correct and working. That includes the side marker and license lamps
Anyone had a similar problem or possible solution?
Thanks in advance
Old Jan 25, 2009 | 07:43 PM
Landseer's Avatar
Landseer
Thats proper behavior. Its described in the owners manual
Old Jan 26, 2009 | 01:53 AM
Arena996's Avatar
Arena996
That is how the system does it's check. It cannot check the circuit until the circuit gets activated via the brake pedal.
JIM
Old Jan 26, 2009 | 12:50 PM
SharkSkin's Avatar
SharkSkin
Normal. Since I back into my parking space at work, sometimes that light doesn't go out till I'm halfway home if I hit all the green lights and nobody cuts me off.
Old Jan 26, 2009 | 01:10 PM
SteveG's Avatar
SteveG
Gregg: You are probably going to want to check ebay from time to time to pick up an Owner's Manual. Depending on your MY (???), they run about $25.
