928 Forum 1978-1995
Sponsored by: 928 Specialists
air pump dissassembly
Old Jan 24, 2009 | 01:18 AM
john gill's Avatar
john gill
Default air pump dissassembly
Hello all
Has anyone any information regarding removal of the bearing in the air pump , it has what appears is a collar in front of the bearing , I am not wanting to force it , all the internal components are easily removed from removal of the rear plate , however the bearing is another matter .
Thanks for any info
Old Jan 24, 2009 | 01:27 AM
Larry928GTS's Avatar
Larry928GTS
Registered User
Not sure if they're the same for all model years or not, but maybe this will help:
http://members.rennlist.com/mgrasser/airpumprebuild.htm
Old Jan 24, 2009 | 01:44 AM
john gill's Avatar
john gill
Thumbs up
Thanks larry
That was exactly as I needed
Thank you very much
Old Jan 24, 2009 | 04:26 PM
JHowell37's Avatar
JHowell37
Do you recall what the dimensions are on the small bearings? I know the big bearing is a generic size that you can get at any hardware store.
