20% off at Harbor Freight
#31
I have yet to make it down there. Im 15 minutes away.
I get ya... had to spend 80 cause you saved $16..... you and my wife must have graduated from the same school!
#32
Rennlist Site Sponsor
Went shopping at HF yesterday, and found a new item - a "Spot Sanding Prep Pen", sku 97292. This is a small pen-shaped device with a brush made of 20,000 glass fibers. Looks as if it will do a good job of removing corrosion on electrical connections and cleaning/prepping rock chips for touchup. Less than $5 at my local store, comes with a brush refill in the handle.
http://www.harborfreightusa.com/usa/...bCategoryName=
#33
I bought some jack stands from H.F. yesterday. My coupon did not have a bar code on it (printed it out from the internet) but the cashier let me slide and just pulled a used coupon from the cash register and scanned it for me. Cool. Thanks Brad.
#36
#37
Guess who's this is.........from today
#40
SeanR.
glad I asked. MM/pan gasket is next on my agenda. had not read the WSM on that procedure yet. I better print the coupon and run to HF too.
;-D
Originally Posted by 911tracker85
SeanR
being a novice wrench... what the heck is that thing for?
It holds the engine in place when you need to remove the engine cross brace for motor mount/pan gasket replacement. Sits on the inner fenders.
;-D
SeanR
