Which Green Giant Injectors?
I see a couple different sellers on Ebay offering 42lb Bosch Green Giant Injectors.
One lists the part # as 028 015 0558
The other lists the part # as 028 015 5968
Thoughts? Advice? It looks like the 5968 is for Volvo, 12.2 Ohms, and the 0558 is for Ford applications at 14.4 Ohms....
Team Owner
What John said makes sense, since my 30lb injectors are for Fords, if memory serves. I just wanted to double check to make sure...I want to avoid doing things twice if possible.
Guys,
Just a related question. I am still looking to find someone within reasonable distance sharktune my car so that I can get rid of the BEGI unit. Is the consensus to go with 42 pound injectors over the 36? (I'm running 24 now)
Thanks and sorry for the Hijack.
Ken
Ken
I am moving to 42lb simply because I think you can run a lower duty cycle at normal fuel pressure--at least, that seems to be Tony's experience. I don't really envision using a smaller pulley (which would probably require another project to add additional idlers and moving the tensioner to the other side to prevent belt slip), but nice to know I have the latitude to do so.
The only trepidation I have is that Tony has seemed to have an issue with flooding with the bigger injectors--but Louie did a similar project with a 90GT and didn't report any problems after tuning.
Rennlist Sponsor
Yes, 470ish RWHP and according to my SharkTuner Run File, 11.93 A/F Ratio @ 6342rpm with 82.5% Injector Duty Cycle.
If your long term goal is 500rwhp and more you should go ahead and install the 42s. FYI, 42s can be tuned perfectly using the SharkTuner.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Looking at the box..
M-9593-f302 is what i have
Spent the day in the garage...horribble job , I know ...beats working
Ive got things sorted out i think...Dont worry about the flooding issues.... PM sent
Thanks DR. I have used #30 set Niklas used in his S4 before #42's that are in it now. Based on your numbers those #30's should be enough for NA 6.5L with usual mods like S3 cams, 968 intake valves and later on also 3" headers and exhaust.
