Did Mercedes manufacture the complete 928 automatic transmissions?
Basic Site Sponsor
Basic Site Sponsor
Actually, if you show up at Mercedes, with a 722 part number, they don't know what it is...they have no 722 numbers. These pieces are apparently pieces made by Mercedes, specifically for Porsche and not available through them.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
so if I go to a mercedes tranny expert, will he recognize, much less be able to service my tranny?
All the parts I changed had 126 parts numbers which seemed to correspond to the Mercedes parts numbers.
BTW, the 722 numbers are quite possibly ZF parts numbers.
/Peter
Here are some MB cars fitted with the 722.3 series auto transmissions.
1995
C220 ........ 7.1 ......... 12.3 .... 722.423/W4A020
C280 ........ 7.1 ......... 12.3 .... 722.424/W4A020
C36 ......... 7.1 ......... 12.3 .... 722.424/W4A020
E300D ....... 6.3 ......... 12.3 .... 722.435/W4A020
E320 ........ 6.9 ......... 12.3 .... 722.369/W4A040
E420 ........ 6.9 ......... 12.3 .... 722.366/W4A040
S320 ........ 6.9 ......... 14.8 .... 722.508/W5A030
S350D ....... 6.9 ......... 12.3 .... 722.367/W4A040
S500 ........ 8.7 ......... 12.3 .... 722.370/W4A040
S600 ........ 8.7 ......... 12.3 .... 722.362/W4A040
SL320 ....... 7.2 ......... 14.8 .... 722.507/W5A030
SL500 ....... 8.7 ......... 12.3 .... 722.364/W4A040
SL600 ....... 8.7 ......... 12.3 .... 722.362/W4A040
1996
E320 ........ 6.3 ......... 12.3 .... 722.369/W4A040
E300D ....... 6.3 ......... 12.3 .... 722.438/W4A020
As advised the part numbers with 126 preface in the PET are the MB parts.
In the main I have found that the MB parts are cheaper then the Porsche supplied parts from MB, and in many instances are far cheaper when purchase from a specalist MB supply shop.
Tails 1990 928S4 Auto
1995
1996
Road Warrior
1 Post
I did the Mercedes factory tour a couple of years ago and the guide was at pains to point out that all Porsche auto trans are made by Mercedes. It just makes so much sense that MB would make the complete transmission unit and then truck it across town to Porsche for fitment.
Uh....no. My 1985 Mercedes-Benz 380SE left the factory with the 722.3, as did all W126 transmissions). The list posted earlier in this thread is not exhaustive. This one is more complete http://www.europeantransmissions.com/Application.htm Mercedes part numbers are confusing, because parts can have multiple part numbers (each part used to make a larger part has its own part number, and that larger part has a part number too).
722 is very much the start to a Mercedes torque converter part number, and the transmission is 722.3.
On the torque ratings, there are 2 722.3s, one is the W4A040 and one is the W4A055 (722.362, which I believe was only found on V12 Mercedes) The 040 and the 055 are torque ratings, if only I knew how to read them. If I had to guess I'd say 400Nm and 550Nm, though that sounds too low since it was put in cars that left the factory with more than 400Nm. Also, given that some (non 722.3) were 020, I'm guessing that's wrong. Nowadays they just say it (like W7A700 means 7 speed good to 700Nm, but I guess it was a code back then).
Basic Sponsor
Great thread and I am resurrecting to try and gain further information.
The auto transmission pan seems to be special to the 928 - talking about 83 to 95 to be specific to start with. It has the rear pipe leading to the reservoir.
Porsche part number was 960 307 031 04 which SS to 722 270 111 2. I am trying to source the pan from Mercedes if possible and as already mentioned Mercedes does not recognize the 722 part number. A pan for a similar gearbox without the pipe to the reservoir sells for less than $100 which is a far cry from the $480 Porsche supplied unit.
If the pan was special to Porsche then I am probably wasting my time. Where any Mercedes cars that were fitted with the same gearbox using a reservoir instead of a dip stick when the gearbox was mounted directly to the engine?
Basic Sponsor
Michael you missed the point - I can buy them all day directly from Porsche but at circa $500 which is way high for what it is.
If I can find the Mercedes part number and they actually made it then I am sure it will be much cheaper.
I should have figured out that I missed the point . I am sure you have already tried, but it comes up empty on the MB catalogue I use. You sell MB stuff Roger?
