help needed with porscheshop.co.uk wheels
hi everyone
i am a bit lost with a product i bought from the here
http://www.porscheshop.co.uk/acatalo...id_wheels.html
they told me that this is a drop replacement on a 86.5
the bodyshop where my car is being done asked me the offset of the fronts on these
looks like i will have to loose the rear spacers to fit these , but i am a bit lost about the fronts , now i keep reading that the correct offset on an 86.5 is et65
.are these correct ?does anyone have these fitted
best regards andre
best regards andre
Hey Andre,
http://www.928registry.org/928-wheels.htm
Check out this link, I think it will have the information your looking for
hi oz928
there are no links on your answer, there is no tech site i can see on the porscheshop site
edco . i went for the cup 3 which are not listed , i bought the stuff already and painted them black
cant get hold of the porscheshop . i was kind of hoping someone else on the list got the same so he could enlighten me
anyway thanks for your replies , keep them coming if you can
regards
andre
regards
andre
What offset do your new front wheels have?
ET60 was the lowest the factory fitted to the car, ET55 seams to be the lowest acceptable on general consensus from reading the various reports before you start getting into potential geometry induced stability problems, ET52 seams common on the cup replica wheels.
Sometimes a ET50 will work I think, but that is REALLY cutting it close...but as long as you don't FULLY compress the suspension you are ok... one big bad bump and you not only have a possible broken wheel, but also fender damage... I think my fronts (they were 938 offsets) are 50's...
My front 7,5" Mille Miglias have ET 52 and I have to say I find the car stable and nice to drive. My girfriends 951 on original CS wheels feels much more unstable on rough roads.
