928 Forum 1978-1995
Sponsored by: 928 Specialists
Oh my eyes.... For real! Caution: hideous 928
Old 12-25-2008 | 03:41 PM
  #31
Mako 928's Avatar
Mako 928
The eyes, look into thier eyes. That's how you know they are dead.
Yes to each thier own. At least they used cars that would have been crushed or parted.
But it still looks like they have no life in them. At least not as we know it.
Old 12-25-2008 | 03:52 PM
  #32
ddarnell's Avatar
ddarnell
It looks like alot of fun to me. Gee I wonder if it's quick.
Merry Christmas
David
Old 12-26-2008 | 12:59 PM
  #33
Ninespub's Avatar
Ninespub
One of the pictures said it all: R E T A R D
Paul Barrera '91 $$$$4
Old 12-27-2008 | 10:52 AM
  #34
CanAmJohn's Avatar
CanAmJohn
Originally Posted by MGW-Fla
Here's the Minnesota Blown Sharks when the yellow one won a concourse.
How is it possible that yellow car won a concourse? The front bumper is clearly not up to standard.
Old 12-27-2008 | 03:23 PM
  #35
928ntslow's Avatar
928ntslow
What the F*** does CHEPORCHE mean?????????...and how the F*** do you pronounce it?!?!?!?
Old 12-27-2008 | 05:12 PM
  #36
largecar379's Avatar
largecar379
Originally Posted by Landseer
Not with all the emissions stuff it would need.
Or a carb.
OK, but one only has to look at the current HEMI---6.1L and 425 hp. fully compliant with EPA and almost 100hp than a GTS......
Originally Posted by Chuck Z
You guys crack me up.......
To each his/her own is right on! Guess we all throw our money away in different ways at the same car.
True, whether it be concours/rotissorie resotoration...or the $500 928 with a transplanted blown BBC.
Originally Posted by Hacker-Pschorr
It's not like the guy chopped up a GTS.
Ok, take what Russ said and replace Hemi with Black Widow ZR1. It was the skunk works option for the Corvette ZR1. Started in 1991 or so, offered 475+hp with full emissions equipment out of 350 cubic inches. Not to mention a lighter motor.
Even without that option, the "regular" ZR1 started with 375hp, jumping to 405 soon after.
Again, another good example of what Porsche missed out on.....
Concours competition is not necessarily about restoring the car back to factory original, but much about how clean the car is......
I won a concours contest with my Euro, and it was so far from original---- but it was the cleanest of the cars in my class, and when the points were totaled up, I got the most points and won...
Aside from all of this, the BBC weighs the same in all aluminum trim (block and heads) as the P-car motor. The extra weight is in the blower and carbs....maybe 150 lbs. When you consider that this package is probably doing an easy 600-700hp, the extra 100 lbs is a no-brainer.
--Russ
Old 12-27-2008 | 05:39 PM
  #37
ew928's Avatar
ew928
Owns the Streets
Needs Camber
Like ChevPorch.
The only true crime of this blown Chebby conversion is the 4" lift kit.
The 928 chassis just have this magical qualities of diving into corner and
ripping through it with careless abandon.
Never driven a pinned rear axle so I don't know if it's the Weissach axle that makes going round bends so much fun.
Old 12-27-2008 | 06:48 PM
  #38
RicerSchnitzzle's Avatar
RicerSchnitzzle
Cheeep-orsche?
She-porch?
Honestly if I was given this car, I'd rock it out on weekend shows. I'd clean it up first, but I'd rock it. I'd also change the intake to a side filtered set up, loose the Mr.Gasket scoop and put a fiberglass scoop over the whole thing. Then drop the ride height back down.
Quick Reply: Oh my eyes.... For real! Caution: hideous 928
