Carrera-lll 18 inch wheels - another good choice for a 928?
#47
Same wheels with 40/265 on rears with stock 21mm spacer.
It's time for new tires, will replace rears with 30/285.
I rolled the fender lip to clear Contis' 40/265, my question is: can I keep spacer or need different thickness?
#49
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
I had to pull the spacer for the 285/30's. Perfect fit. It did rub on the inside at sum point but doesn't do it any more. You need to remember that the pilot sports have a edge that protects the rims so their actually wider than the 285's on the side and that's the part that rubbed not the top of the tread.
#50
#51
Thanks for the reply, will not buy pilot sports, probably Sumitomos for performance and price.
How much wider are 285/30 compared to 265/40?
If I remove spacers, open ended lug nuts are necessary.
I was hoping to leave spacer inplace, right now I approximately have !/2" space; tire to fender lip.
#52
![Name: GJCarerra 3.jpg
Size: 62.9 KB](https://rennlist.com/forums/attachments/928-forum/338740d1235408548-carrera-lll-18-inch-wheels-another-good-choice-for-a-928-gjcarerra-3.jpg)
How is the ride with 285/30/18 rear? I'm still debating on 265/35 vs 285/30.
Aryan
What you would expect with but with Bilsteins and the Pilot Sport Ribs I feel is a great combination for the S4. Previously had on Cup 11's with S0-3's all round that was very similar ride. Handling now is incredible. The 285/295's x 30 bring the speedo nearly back to correct speed reading.
OZSHARK
#54
#56
#60
I looked at the carerra 3s but decided to fit carerra classic 19s instead as they have a bit more design to them i.e. a few more curves and bumps. 19x8 et 57 a perfect fit within specs for the S4 and 19x 11 et 65 rear (21mm spacers). The car looks and handles really well.
