Question of non-stop cooling fans
Received 1,643 Likes
Test Points:
All testing done at plugs to fan controller. Fan controller is located in the 'hump' between the passenger seat and the door. Controller plugs are, IIRC, labeled. If not, Plug II is the lower plug. Plug I is the upper plug.
Short hand:
"P1-3" means Plug I, pin 3
"P2-7" means Plug II, pin 2
1) Temperature sender in radiator.
Resistance between P2-1 and P1-7
60 degrees C: 3862 +/- 150 ohm
85 degrees C: 1582 +/- 54 ohm
100 degrees C: 967 +/- 36 ohm
4) Temperature switch intake / auto transmission temp switch
Resistance between P2-3 and P1-7
0 ohm, intake temperature > 87.5
Inf ohm, intake temperature < 82.5
0 ohm, transaxle temperature > 110
Inf ohm, transaxle temperature < 105
Be careful disconnecting the plugs. There's not much slack in the harnesses. I've found bad/old/busted solder joints on the pins in the plugs. Might not be a bad idea to - carefully - unsnap the back off the plugs and examine the pins.
Short hand:
I had a similar problem, turned out to be a faulty fan control unit. Located under the hood in front of the radiator. Passenger side. Looks like a black amplifier with fins.
Here's a link that may help.
http://jenniskens.livedsl.nl/Technic...0/MyTip011.htm
Here is a great start...
http://www.billsworkshop.com/P928S4/resources.htm
Then head down to Tony's Silver Bullet page.
If memory cells are still intact - you'll find it in the "Where is it located"
here
http://members.rennlist.com/v1uhoh/underthe.htm
Many thanks to Tony....
You're welcome![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
here
You're welcome
I followed the instructions from the above link and when I pulled the wires off the temp sensor and closed the hood the fans did not run (after warmed up prior). Reattached them and closed the hood and they ran again.
I got a new temp sensor ordered for $15.14 + shipping.
Thanks again!
