WTB: S4 Air Flaps and Fan Motor
According to this link he took the whole nose off. Are you saying that is not needed? If I remove the flap should I also take out the shroud?
https://rennlist.com/forums/928-foru...-question.html
The S4 still runs too warm when pushed hard. It's my daily driver and works fine for that. However, I can't take it to the track until I figure this out. The problem is not in the usual list of things suggested here in Rennlist (Search may be my friend but the answer is still elusive). Louie gave me some other ideas that I'll check out once the weather warms up a bit. They're predicting 17 degrees (F) this weekend. That's more than my garage heater can deal with.
Harvey
Archive Gatekeeper
You don't HAVE to take the nose off- it would be pretty easy to just reach in and either break off the flaps or use a hacksaw blade and cut them out of the frame. I just wanted to see if it could be done non-destructively. I think you should definitely keep the shroud- there's a reason they went to the trouble of ducting the air towards the radiator, and put those vertical slats at the rear edge of the radiator to force airflow thru the rad.
Rich
What you mention about ducting air towards the radiator...makes me think that the flaps probably result in BETTER cooling...rather that what some think. Obviously, if the flaps do not open, it would result in must reduced cooling.
Harvey
I think you have a valid point, Harvey. With the flaps open there is minimal obstruction and they provide a directional component to direct the air slightly upward toward the center of the radiator rather than dumping it in at the bottom.
Archive Gatekeeper
Hmm-
Good point, guys, but didn't they do away with the flaps in '91? Was there a concomitant change in the ducting in '91? Perhaps I'll have to append the Flapectomy to a Flap R&R.....
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Yes, the flaps disappeared in '91. My '91GT doesn't have them and the ducting looks the same as on the '90. Were the flaps eliminated to improve cooling, or to cut cost? The fate of the 928 was already being written by '91 so my bet is that it was an easy to do cost cutting project. I wish someone who did the flapectomy also had good before and after data to support one position or the other. Pun intended, heh, heh. I took them out of my '90, but for other reasons.
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
Doncha think the '89 GT runs hotter because it's a "hotter car" to begin with?"
BTW, look at Louie's rear tires (in his avatar) and I think you'll get some idea of why he might have removed his flaps. In order to spin his tires at will at about any speed (dry pavement too), just by stomping the gas, he had to put considerably more horses under the hood area. Interestingly, he runs cool anyway.
H2
Mike,
H2
H2
We think only about failure modes, therefore only the worse. How about an owner who lives in the northern wilderness, in a place like, say, Alberta? It gets cold there in the winter, a situation for which those intake air flaps were intended. Causes the motor to come up to temp sooner, gets warmer air in the intake to improve cold-weather driveability, etc.
Harvey................I removed the flaps and motor:
1) one less failure point to be concerned with
2) it was deleted in future MYs and I would have thought Porsche would have considered all consequences.
If you want they're in the frozen quonset; I could rescue them in.........March?
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
