928 Forum 1978-1995
Sponsored by: 928 Specialists
Tail Light Warning
Old 11-28-2008, 04:13 PM
SharkSkin
SharkSkin's Avatar
Originally Posted by Tom Rathjen
When I start the car, the central warning light comes on after about 10 seconds or so. Then, a few seconds after that, the tailight warning comes on. (And then I can press that central warning light button to clear it, but the tailight warning stays on.) This happens with the lights off.
To me, this implies that something is miswired or shorted. To the best of my recollection, I have never seen a tail lamp warning(and I've seen my share) with the lights off. With the light switch in the parking light or headlight position, this circuit becomes active. Since the light unit compares voltage drop across bulbs from side to side, I don't see how you can get a warning with the lights off. My setup is different from yours, I have a separate panel for warning lights(pic below), but as far as I can tell it works the same way.
Old 11-28-2008, 08:07 PM
Landseer
Landseer's Avatar
I have it when the light relay is removed or bad.
Old 12-03-2008, 07:07 PM
Tom Rathjen
Tom Rathjen's Avatar
I found the problem. After not being able to get it working after replacing all taillight and side marker bulbs (again), I decided to jumper the BCU. But when taking it out, I discovered that tapping on it made the warning come and go. So....I took apart the BCU, and figured out which component(s) made the warning flicker when wiggled, and then re-soldered those connections. And put it all back together, and it works. Yea!
Old 12-03-2008, 08:47 PM
6mil928
6mil928's Avatar
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Where is this thing at? On my 81 I have the light on all the time regardless of the lights switch being on. All my markers and bulbs are workin.
Old 12-04-2008, 07:35 AM
Tom Rathjen
It's under the wooden door in the passenger side footwell, just above the fuse and relay panel. It is a black plastic box about the size of a cigarette box, with a metal bracket attached to it. The same bolts that hold the hinges for the wooden door secure it in place. (And to open it and get to the circuit board inside, there are four small phillips screws on one side.)
Old 12-04-2008, 11:01 AM
EC928NC
EC928NC's Avatar
I found the problem.....I took apart the BCU, and figured out which component(s) made the warning flicker when wiggled, and then re-soldered those connections. And put it all back together, and it works. Yea!
Nicely done Tom! Congrats.
Old 12-06-2008, 11:14 AM
6mil928
6mil928's Avatar
Can it be unplugged to kill these stupid bulb warning lights? I've also got a stop lamp warning light as well.
Old 12-06-2008, 12:12 PM
Landseer
Landseer's Avatar
No, the power routes through it. It can be bypassed, repaired(nice job) or replaced.
Old 12-06-2008, 12:51 PM
6mil928
6mil928's Avatar
Chris do you know how to bypass it ? I'm going to check the wire connector behind the tool holder but I may need to bypass it to kill it if it doesn't work.
Old 12-06-2008, 01:03 PM
Landseer
Landseer's Avatar
Yes, post #3 has a link where I investigated it. Mine had been back-fed power, so inside was cooked and wouldn't pass power forward through it anymore.
I researched bypass and verified it worked, then later, got a used unit from Roger. Unfortunately, it passed power but gave the warning, so it improved it, but wasn't perfect. Now, from this thread, I may have a fix by resoldering.
Anyway, search BCU, because Porken did it also much earlier than me, and he had a clean way of bypassing it from an executional perspective.
Deep searches yielded advice from WallyP also on the subject, but somewhere in those replies the wrong wires were reported as the ones to bypass, that slowed me down a little bit.
Old 12-06-2008, 01:56 PM
6mil928
6mil928's Avatar
Chris as always your awesome!!! Nice write up by the way. Jason
Old 01-15-2009, 07:13 PM
Hi Ho Silver
Hi Ho Silver's Avatar
Is the BCU made by BOSCH and is slightly fatter than a cigarette packet? Ive got the flashing warning light. I could send a picture if that helps. Many thanks Peter
Quick Reply: Tail Light Warning
