Replacing Ignition Switch
To replace the ignition switch on a 82 928 Euro S, does the dash box have to be removed? And is there anyone or place that can repair the printed circuit board on the back of my instrument panel? Thanks for your time.
Team Owner
If your working on the POD disconnect the battery first.
follow the WSM for removal instructions so you dont break any of the pod switches. ( to remove the pod switched gently pull on the head of each switch it will slide off then press in one tab at a time to slide the switch housing out of the pod)
Note that the pod is made of aluminum and if a switch body hits it with the battery connected then you will fry a wire back the CE panel .
Once the pod is off, the ignition switch is removed with 2 phillips screws that hold it to the back of the key portion of the ignition switch.
As far as the wave circuit you might be able to resolder a wire into the connection points but what is the problem exactly???
The Lady's Man
definately has to come out..an hour is good, 20 minutes is amazing. I attempted this but then quit figuring I'd wait until I could get a new pod so it could all be done at once. I also need to do the ignition and the dash lights.
Some hints on the Pod removal and isntallation.
1. You can see what you are doing a lot better if you remove all the switches first. They pull out from the front.
2. when you go to put it back in, put the bolts and gromits on the pod. cluster first. then look threw the switch holes to line it up on its mount.
I repaired the circuit board my self on my 79. it took some time and some soldering skill and super glue.
The problem with the circuit board is that the ends of the circuit panel are peeling apart and breaking where they fit in the plug. Anything can be done? I looked up how to reprint a new one, but don't feel I have the skills to do that.
And thanks for the advice on the ignition switch.
Here is Dwayne's write up on pod removal. This should help.
https://rennlist.com/forums/928-forum/424856-pod-removal-and-instrument-cluster-repair-w-pics-part-i.html
Here is some info about the printed circuit film.
https://rennlist.com/forums/showthre...d+circuit+film
