Replacing Motor Mounts, Solid, Hyd??
Not as bad as I was anxiously expecting, actually. I have the will and the tools to make a winter project of this, but no I've got no garage or lift. And fortunately, money is easier for me to find these days than time.
Interestingly, they refused to install the solid Anchor mounts - they insisted they will not last as long as the OEM mounts. Hmm... kinda throws another log on the fire of this thread, don't it?
I would prefer to use OEM parts whenever possible, but was balking at the $400 price tag, but the shop found them for 20% less, so what the hell - keep it real.
I have fitted both types of aftermarket Hydro and solids, I wouldnt be able to tell you what car had what kind of motormount by driving it, much less looking at it.
The mounts are made to isolate the engine driveline from the chassis and hold the powerplant in a predetermined position. So if your oil pans is level with the bottom of the crossmember with the mounts you have you should be good to go.. Solid or hydro thats the question??? I have found that virtually all of the hydro mounts I have replaced have been empty, I would stick with the solid mounts as there are less things that will fail and the the difference in aftermarket hydro VS soild vib dampening is almost a moot point. Pick your favorite, It cost the same amount of time/ money to replace the motormounts so then you now have a choice do it once every 5 years (est) or once till the soilids collapse
Do you have a picture or diagram to illustrate.
sorry no picture, but generally speaking when the mounts go bad IE sag the oil pan will be lower than the bottom cover on the crossmember its easy to check, stick you head under the front of the car and look at the pan VS crossmember, if you want to do a closer inspection try sticking your finger between the pan and the crossmember once the mounts crush there is little room to fit your finger tween the parts
Peter
My tranny mounts are apparently shot too, so they want to do them all at the same time, as well as the steering rack bushings, the oil pan gasket, and an oil change - just a tick over $2k of work.
Ugh... I decided to have them do the intake R&R and ISV replacement instead (for about the same money) - not having a steady idle and stalling when the A/C is on is far more annoying than vibrations in the chassis.
Fresh mounts all around next year!
It adds up quickly.
Its also a dirty job on jackstands, and needs to be done in a garage, especially where you live.
Wish we were nearby could help you with it.
Which reminds me, JADZ 928 should be about ready for some help on his S4 about now....
I am not buying the factory mounts lasting longer than the solids, if you bought the soilids for about 80.00 the rest of the 400.00 could be spent on rack bushes, PS lines, resivour, pan gasket. It sounds to me like the shops wanting to make money rather than take care of a customer.
The solid mounts will last longer than the factory filled units and you wont be able to tell the difference except when the HYDro units fail
The thing is, I have an excellent-condition, low-mileage 1989 GT, and it's worth a couple of hundred dollars to me to "keep it real" by using EOM parts whenever possible - I don't want to end up with a Frankenshark for the sake of saving a few dollars.
Chronic Tool Dropper
I know there was an informal 'survey' a whil;e back, asking users of non-Porsche mounts to share data on lifespan. Might by appropriate to update the data periodically. Part of the discussion from the OEM/Porsche mounts side of the discussion is to define what a failed mount is. I know we use the finger-in-the-hooks test, perhaps that needs to be a bit more definitive. Like how much room is max for a mount to be considered good.
I tested/measured mine immediately following installation, using a straightedge along the top of the intake to the crossbar. It was almost exactly a straight line top of manifold to top of bar. Saves some of the crawling. The aftermarket mounts are reputed to be slightly shorter, to the point where some have recommended adding spacer washers to make up the difference. Point is that all MM installs need a baseline measurement, so that you can easily determine over time what the deterioration is.
Even with new injectors; 2k for a top end job is a lot of dough IMO. If possible, work like top end work is a great candidate for a few Saturdays with Porsche-philes. But I know without tools and workspace, that it has to be farmed out. Regardless, I'm sure that you'll enjoy the improvement in driveability when all is done.
How does a solid mount fail? I know exactly how a hydralic ones does, but a solid? For some reason I am doubting that. Unless the mount was bathed in something to make the actual rubber melt away from the mounting points, I don't see it happening.
Sean the only thing i could think is that the mounts were flawed from the start maybe the rubber that was used wasnt cured properly and thus crumbled.
I have installed about 14 sets of the aftermarket mounts and from the cars that i have seen after installation none have any signs of failure or sagging. Both of my cars have them one with 12000 miles and 4 years still look like new.
DrBob I do agree with that idea of taking measuments .
I do also install 2 flat washers under the mounts to add a bit of height, and there is still the problem of fitting the steering rack to the Xmember as sometimes the rack lines will be very close, unless the stud is cut off to almost 1 to 2 threads after the nut is on.
There doesnt seem to be any repeatability on fittments, some racks clear and other are close and others hit the stud.
With a straight edge (on a S4 or later)the manifold should line up with the cross brace on top or you can check the underside to see if the pan is flush or slightly above level with the oil pan
I really wanted to do the intake R&R myself over a winter, but without a lit, secure garage to work in, it ain't gonna happen. Maybe next year we'll be in a new house with a nice oversized garage I can put a lift in, and I can do my own motor & tranny mount job then...
I'm on the fence about OPG because it was done recently, though with OEM cork.
Regarding part alternatives... as long as they're functional, reliable, cost effective to OEM parts. The older these cars get, and as Porsche parts continue becoming NLA, sometimes necessity outweighs fundementals.
For the record, Chewy's OEM hyd MM's are 6 years old and 30K miles. So I guess that means they're about shot.
