928 Forum 1978-1995
Sponsored by: 928 Specialists
Check your knock sensors
Old 10-24-2008, 11:25 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
87 has no diagnostic capability unless you replace the chips inside the LH and EZK with newer model year (88+) chips that added fault memory.
Two sources of 928 diagnostic testers:
JDS Porsche Spanner: Handheld tool that is quite similar to the Porsche Hammer diagnostic tool.
Theo Jennisken's 928 Diagnostic: PC software based (I use an old laptop) with an interface box. The PC allows the diagnostic program to run very quickly and allows direct access to individual tests.
I believe these sources can provide the updated chips you would need as well.
Old 10-24-2008, 11:32 PM
David L. Lutz
David L. Lutz's Avatar
Bill,
Thanks for the info.
I am currently running with the Murf stage III chips (both in the LH and EZK) that Tim provides with the kit. Do you know whether or not these have that capability?
Old 10-24-2008, 11:44 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by David L. Lutz
Bill,
I would think so. Although yesterday I tried to connect to an 87 LH that had a similar chip from Tim in it, and the diagnostic testers would not connect. Maybe something else was wrong with that LH, although the car ran OK with it.
Old 10-25-2008, 05:54 AM
John Speake
John Speake's Avatar
SharkTuned chips are not compatable with diagnostic testers. The SharkTuner will of course give full real time monitoring of all parameters required for fault identification.
Old 10-25-2008, 06:48 AM
Peter F
Peter F's Avatar
Hey John,
when will your seccond version of Sharktuner be available?
Put me on the list for wanting one.
/Peter
Old 10-25-2008, 06:53 AM
John Speake
Hello Peter
We are testing the first pre-production unit now..... I will announce on RL, hopefully in the next couple of months.
Thanks for your interest !
Originally Posted by Peter F
Hey John,
/Peter
Old 10-25-2008, 11:05 AM
the flyin' scotsman
the flyin' scotsman's Avatar
hi John...............can the existing and the new ST perform all the tests that your spanner can?
Old 10-25-2008, 11:38 AM
John Speake
Hi Malcom,
More tests than in the Spanner menu, and all in real time. e.g. Idle stabliser postion, O2 adaptation status, flappy position, battery voltage, with datalogging are some of the additional available.
The ST User manuals are available for download on my website.
Old 10-25-2008, 11:54 AM
Jadz928
Jadz928's Avatar
Since this is somewhat about diagnostics.. could someone tell me where to find that 19pin diagnostic port?
Old 10-25-2008, 11:55 AM
David L. Lutz
From this I would say my only option using Tim's stage III chips is using the sharktuner?
Roger if your reading, do you have them in stock? Give me a call...
Also does it come with whatever I need to hook it up to an 87?
Old 10-25-2008, 12:10 PM
the flyin' scotsman
Hi Malcom,
Thank you John.............just looked at the manuals on your site; great stuff.
Does Louie carry the ST and related peripherals?
Old 10-25-2008, 12:42 PM
JP Rodkey
JP Rodkey's Avatar
It's under the same cover with the stereo amplifier - between passenger seat and door opening. Once you remove the two knurled hold-down screws and remove the cover (it's carpeted), you will see a round capped connector.
Old 10-25-2008, 12:56 PM
John Speake
Hi Jim
On your MY87 it is in facta 12way rectangular connector mounted on the same plate that holds the LH and EZK ECUs. You will also need to upgrade your EPROMs to MY88 or later.
Old 10-25-2008, 12:57 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
That's odd. A MY90 LH that George had running a Sharktuned chip did connect to the diagnostic tester and gave us the error codes we needed.
So, if a Sharktuned chip will not connect to a diagnostic tester this sounds like a real problem for people who have a Sharktuned chip and have a problem, like George, at some later date and do not own or have good access to a Sharktuner. So, the answer for them is to swap in a stock MY88+ chip for testing even though it will be way off tuning wise?
I imagine this also true for PEMs, right?
Old 10-25-2008, 01:03 PM
John Speake
DR stocks SharkTuners.... Louie has spare ribbon cable adaptors.
Quick Reply: Check your knock sensors
